× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RBR750:Failure to download from Google Play store, ver 3.2.16.22
FredJBK
Model Number: RBR750/RBK753S
Ver: 3.2.16.22
I'm unable to download anything from the Google Playstore.  I started a case awhile back on it, but I only had one device.  Now I have multiple with the same issue.
Fire Tablet HD8 (2020) x2 with Playstore side loaded.
Samsung Tab A with Play store
Google TV
The devices can brows the play store, but they are not actually able to download anything from the store itself.
Awhile back I had a case, but at the time, as mentioned, I was only had one device and the device was blamed.
Now, if I reset the device it works initially, but unfortunately I was unable to find the toggle for the actual failure.  I'm hoping that Netgear would be willing to work with me to find the fault so it can be fixed.  This may be a rare case, but it is still a failure of the firmware of the product.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: RBR750:Failure to download from Google Play store, ver 3.2.16.22
You'd get more help in the proper forum. You posted in the general router forum and not the orbi ax forum. (gets to be confusing)
Orbi (AX) - NETGEAR Communities
I'd also include what modem/gateway you have when you post.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 712 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
