× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WIFI Range Extender Models EX6100 and EXS6190
12Career
Follower
Hi, we've just had NBN installed today NSW Australia. The above models of our wifi range extenders now don't work. Can anyone tell me what I need to do to get them working NBN compatable?
Thank you so much 🙂
Message 1 of 4
Guru
Re: WIFI Range Extender Models EX6100 and EXS6190
Are you trying to set them up using the wps method?
That could be the issue.
Factory reset the extenders (push and hold reset for 7-15 seconds while they're fully powered on), then during the install, use the installation wizard and NOT wps.
Message 2 of 4
Lokerd
I actually need the entire setup procedures.  We moved house and I have not been able to locate the original instructions.
Message 3 of 4
Guru
find them here:
https://www.netgear.com/support/product/EX6100.aspx
make sure to select the correct version from the drop down box
the EXS6190 is made by netgear for telstra. so netgear doesn't have a manual. But it should be similar to how you install the ex6100
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1583 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
