× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNDR3700 reset to factory settings on its own
jcicero
Follower
My wife contacted my while I was away from home for an hour because ROKU wouldn't connect. After returning home, I noted that my SSID had reset to NETGEAR and the connection was no longer secured with my WPA password.
I'm well past the 90 day and year warranties. Is this a sign of nefarious hackers or equipment failure? It makes me nervous that it happened without any user intervention.
Any advice/help is greatly appreciated.
Message 1 of 2
Accepted Solutions
Re: WNDR3700 reset to factory settings on its own
Just change the SSID and password to something you want.
Maybe the device was reset to the factory defaults somehow.
Message 2 of 2
All Replies
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3320 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
