- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDR3700 suddenly slower
- Mark as New
- Bookmark
- Subscribe
- Permalink
After many tears of good service to the far-flung corners of my house, my WNDR3700 has suddenly slowed to a crawl. If I put a Wi-Fi computer right next to the router the signal is strong, but it drops off dramatically if I move even 1/4 of the normal operating distance (tested with Acrylic Wi-Fi Home). Nothing has changed as far as settings are concerned. I'm running Win 10; I'm not sure of the firmware, but neither settings nor enviroment have changed. My office computer is connected to the WNDR3700 by ethernet and is OK, but a printer, two laptops, and a Roku streamer are affected. All worked well until yesterday. Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDR3700 suddenly slower
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute then back ON.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might be time to look for an upgrade. The original was released in 2009 and was one of the first (ish) consumer gigabit devices.
Its going on 13 years old and has been surpassed by several generations or wireless routers.
If you even have half decent speeds from your isp, you'll see a significant improvement going from it to a current generation device.
Can you try to fix it? Sure.
Is it worth trying to fix? debatable. maybe if you're on a pretty slow dial up connection. Sure. I'm not a fan of getting rid of functional electronics but I'd be looking at upgrading.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The firmware is V1.0.7.98NA. The modem is a Arris (Optimum) TM822. I believe that no factory reset has been done since the original installation. Pulling the power on the moden didn't help. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Last resort would be a factory reset and setup from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your suggestions. I think I have found the problem. There Is a hidden router channel that mimics the main channel and slows it down. i was able to change the main channel on the router and it sped up dramatically. However the hidden channel jumped to the new channel and the router once again slowed down. the question is how I can rid the hidden channel from the router, or keep it from changing on its own?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you mean about this hidden channel?
Do you have a screen capture?
Do you have any repeaters or extenders running?
Any wifi nieghbors near by?
What happens if you change the SSID name and password to something different temporarily?
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you say hidden channel do you mean someone else's wifi on the same channel as your router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks to the community for your helpful suggestions. I finally decided that after ten years of faithful service that it's time to retire my router and replace it with something that has the required signal strength/range. I'm now looking into a variety of mesh units and expect to make a purchase soon. Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Probably a great plan.
got a specific one in mind?
What speeds do you pay for?
How big is your home?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suscribe to Optimum's 200 service. The house is approximately 2100 sq. ft.; it is older construction with a lot of walls; it's a ranch so the floor plan is spread out. I've been looking at the Reyee WiFi 6 Router. It's inexpensive at $119.99 with a $30 coupon on Amazon Prime. It got decent reviews for a simple mesh-able unit, and at that price worth futzing with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Never heard of Reyee but it gets pretty good reviews.
Few downfalls because its uses lower spec components but for a 200mbps connection it shouldn't have an issue saturating it.
If you're not looking at adding satellites, one thing you might consider is if you search amazon for "AX5700 renewed netgear", you'll come up with a RAX75 (doesn't say it on the product page). Its not much more and you can always buy a 3rd party warranty through amazon for cheap if you're worried about renewed (not always a bad idea with renewed). Pretty solid router (from my experience) and going to have a bit more performance/specs than the Reyee.
