- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDR4300 v2 Slow speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I recently ran into an issue that my WNDR4300 v2 router has slow speed, especially for wired connection. For instance, online video stream start constant buffering 1-2 mins after opening; BT download speed remarkably fall from 2-3 Mb/s to 20-80 kb/s; Downloading in browser start with high speed but end up with 0 speed after serveral seconds. After I reboot the router the speed would come back for like 10- 20 mins and then falls again. If I plug my computer directly into port on the wall the speed would be normal.
I have 100Mbps Internet service. My firmware is 1.0.0.32.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDR4300 v2 Slow speed
Welcome to the community, @az6351
Did you try to factory reset the router?
It might be possible that the router is slowly degrading.
Have you also tried using all LAN ports available? Is it the same result for all?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
