Orbi WiFi 7 RBE973
WNR3500Lv2: Firmware Version 1.2.0.72 won't downlad
mr_ckw
Tutor
When attempting to download this firmware the process begins, a file is created, but no data is downloaded. Consequently I get a zero length file. Does anyone have a resolution for this issue, or, maybe a copy of the firmware you could share?
Clark
Message 1 of 6
Accepted Solutions
mr_ckw
Tutor
Re: WNR3500Lv2: Firmware Version 1.2.0.72 won't downlad
Greetings,
Just used Firefox on the same computer, and it downloaded the file instantly, without issue.  Thanks again for your suggestions!
Clark
Message 5 of 6
All Replies
Guru
I just manually downloaded and extracted it without issues.
Have you tried a different device?
https://www.netgear.com/support/product/wnr3500lv2.aspx#download
Message 2 of 6
mr_ckw
Tutor
Thank you for the info! I've only tried it with the Safari browser on an iMac. Knowing you were able to download and access the file is a good thing. I have other Apple devices, and, some Linux based computers. I'll see if I can have some success using those.
Again, thank you
Clark
Message 3 of 6
Guru
Hope that works for you!
Message 4 of 6
mr_ckw
Tutor
Greetings,
Clark
Message 5 of 6
Guru
Glad to see it worked!
You can mark it solved so others aren't still trying to fix it 🙂
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1676 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
