× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WPA2 Passphrase Not Working
Talan1177
This morning we had a brief power outage (about a second).  Since then, nothing can connect to the 2.4GHz network.  Now the 5GHz network works just fine, however we have some smart home equipment (lights, outlets, etc...) that can only connect to the 2.4GHz network.  I have verified repeatedly that the password is correct.  However nothing will connect to it.  Computers, phones, tablets, not one thing.  I have power cycled several times.  I even tried changing the passphrase to no avail.  It still says that I am not using the proper passphrase.  My next step in my head is a factory reset.  I really really don't wanna have to do that.  It would be such a pain in the butt to set everything back up again.
Model: WNDR3400v3|N600 Wireless Dual Band Router
Message 1 of 2
Accepted Solutions
Talan1177
Re: WPA2 Passphrase Not Working
I ended up doing a factory reset and the problem is solved.
Message 2 of 2
All Replies
Talan1177
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1420 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
