× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
netgear wndr3400v2 wont let new devices on wireless anymore?
dough041
I use my router through my comcast cable router ( bridged) and it functions fine except for a while now I can't add any new devices to the access control ? It shows them under allowed devices not connected and I can no longer get them on the first allowed/connected screen. I usually restrict it so a new device mac address needs to be input but either way anymore I can no longer get a new device to connect wirelessly? I only have approx 7 things on it cuurently...any help would be really appreciated. I just got a new TV and cant connect. I first noticed when I tried to let someone get onto the router for their phone wifi...sorry if not so clear .
Message 1 of 10
Accepted Solutions
dough041
Re: netgear wndr3400v2 wont let new devices on wireless anymore?
Thanks a lot for your help Elaine... Got what you said. Not sure if I'll pull the trigger to reset quite yet. Why do today what you can put off until tomorrow...hahaha
Message 9 of 10
All Replies
ElaineM
NETGEAR Employee Retired
Hi @dough041
Welcome to the community!
Looks like you're unable to add devices under Access Control.
Will you be able to add another device when you take one from the list?
What are the settings you have enabled on the router?
Do you have Port Forwarding, Block Sites, Block Services, USB Storage enabled?
How many devices are connected (wired and wireless)?
Message 2 of 10
dough041
I can access the wireless on all 7 devices ( 2 wired/6 wireless). However for the last 8 months or so when I try to let family enter their MAC address to my allowed list it won't enable them to get on the wifi such as iPhones, smart tv etc. My android phone does connect but doesn't show up on the allowed list.Am afraid to hard reset router as maybe then it will not allow me to connect any new devices including ones currently on like roku, Amazon etc...
Message 3 of 10
ElaineM
Sounds like a hard reset may be needed here.
You may want to backup the settings of your router before resetting.
Then once done, you may restore the settings.
Backup and Restore feature
Message 4 of 10
dough041
Maybe a stupid question but how do you backup my router settings?
Message 5 of 10
ElaineM
The link was provided in my previous response.
Message 6 of 10
dough041
Thanks for the info on backing up my router settings. Although it was saved as a config file and I can't bring that up to view?
I did run a Ethernet cable from a new TV ( couldn't connect wirelessly ) and it ran instantly. However it is not listed as an allowed / connected device.
This has me stumped. Thanks for any ideas or thoughts. I am a little reluctant to do a hard reset as I am  concerned I would have to reconfigure all the devices connected to the router currently and I would possibly be in the position I am now not being able to add devices? At least for now it connects my iPad and roku etc....
Message 7 of 10
ElaineM
You're welcome. The only way you can view the settings is if you'll take a screenshot of each page of the router.
The configuration file that you have download cannot be viewed. It contains all the settings that's currently configured on your router.
If you decided to do a reset then you can always get the settings back by using the restore feature.
Message 8 of 10
dough041
Message 9 of 10
ElaineM
No problem. Just let us know should you need further assistance.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 8918 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
