× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
problem in accessing default gateway
varonica_1
Initiate
Hello Friends I am using netgear R6220 Ac 1200. I am very bad in tec. So i have tried to access 192.168.1.1 router login page. Even I visited  www.routerlogin.net
I dont know why my IP is 192.168.140.20 but it supposed to be 192.168.1.1
I don't know what the problem is here.
Model: Dual Band
Message 1 of 3
Accepted Solutions
Guru
Re: problem in accessing default gateway
What modem are you connected to?
many times people are running a modem/router combo device and then hooking another router to it. it causes many issues and the one you're having can be one of them.
https://kb.netgear.com/30186/What-is-Double-NAT
If this is the case, you'll either want your combo device in pass through/gateway/modem only mode or you'll want to disable wifi on it and enable access point mode on the netgear device.
Message 2 of 3
All Replies
Guru
Message 2 of 3
antinode
Guru
> [...] I am very bad in tec. So i have tried to access 192.168.1.1
> router login page. [...]
   How many people here believe that someone who's "very bad in tec"
would include a hyperlink to
"https://192-168-routerlogin.com/192-168-1-1/", and label it "access
192.168.1.1", as was done in this post?
   For a remarkably synchronous thread which also provides a cryptic
link to the same site, see:
      https://community.netgear.com/t5/x/x/m-p/1830060
   Must be a coincidence.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1581 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
