Jayau
Jan 29, 2018Follower
Link 2 GS748T switch with Microsoft NIC Teaming is set
Hi There,
I have Windows Server 2012 R2 with 4 NICs Teaming. I have 2 of GS748T switches. What is the best way to set it up (both hardware and software). Should I remove NIC Teaming and use LAG on the switch? Should all 4 cables plug-in same switch? If I use 1 cable to uplink to other one, the speed will be 1GB, right?
Appreciated the reply.
J
The question is ... what for and how do you use this server? Start your reading .... for example here -> NIC Teaming in Windows Server 2012 – Do I Need to Configure My Switch?
For the switch interconnection ... again, it depends on the usage, the bandwidth. Create a trunk here can help.
1 Reply
