- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
VLAN configuration - GS728TP
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have three Netgear GS728TP PoE smart switches, linked in a chain by fibre optic cables as they are in different locations around the site, more than 100 metres apart. In switch1 I have a VLAN-aware DSL router which is used by my corporate network for internet access. Switch 1 links to switch2 and switch2 then links to switch3. In switch3 I want to connect a PC to be used by a visitor. The visitor requires internet access only and I want to be sure that he cannot access our corporate network.
I want to setup a VLAN for this one PC so that it can obtain an IP address from the router on switch 1 and access the internet only.
Can anyone advise me on the best way to do this?
Thanks
David
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi infologicit,
Welcome to the community! 🙂
Let me share the article below and used it as your reference guide:
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi infologicit,
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VLAN configuration - GS728TP
Hi DaneA
Thanks for the link, that answered a lot of questions for me. My setup is slightly more complicated than the example, with three switches involved, with the PC being connected to switch 3 and the router connected to switch 1. Are there any further things that I need to consider with having three switches? I notice that under the section heading "To assign the ports and set the port VLAN IDs:", point 3 the screenshot shows port 1 has been tagged. Do I need to tag any ports on any of the three switches?
Thanks
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ports connecting the switches should be set as tagged ports because its a trunk link. For example: port 5 of Switch 1 is connected to port 5 of Switch 2. Then, port 6 of Switch 2 is connected to port 6 of Switch 3. Port 5 of both Switch 1 and Switch 2 should be set as tagged port with a PVID of 1 and should be a member of all VLANs. The same goes with port 6 of both Switch 2 and Switch 3 should also be set as tagged port with a PVID of 1 and should be a member of all VLANs.
Kindly refer to the article below:
How do I setup a VLAN trunk link between two NETGEAR switches?
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks DaneA, that worked a treat!
