daniel-germany's avatar
Oct 29, 2018
network slow: 3 switches between router and pc
Hi,
i have a network that distributes an internet connection (1gbit) to 17 house staircases over copper with 6 endpoints each, so that at each endpoint a maximum of 32MBit up/down can be used and all subnodes are protected via VLANs, so that endpoints cannot see, disturb or connect each other.
Since a few weeks more endpoints were connected and speed problems started.
speed drops under 1MBit or fully stops, while the internet connection is most unused.
Since the endpoints are spread over almost 250m, a GS110tp switch was connected every 80m to get over the 100m limit.
All computers connected to GS108E switches behind these two GS110tp switches often have problems.
All switches have VLANs configured - configuration shown in the picture.
All stairway switches have 32MBit up/down limits configured, except at the uplink port.
I hope the structure is visible in the picture. Computers at the switches in the red rectangle have problems.
Where and how could I look for the problem? What could go wrong here?
i updated all firmwares yesterday, however no improvement.
the 90 days warranty is over, so I don't have free support from Netgear anymore. :(
Best regards,
Daniel
the network with some descriptions
  • looks like i can not extend the 100m limit with switches.
    so i need to use fibre for the 2 long distances (90m and 170m) or replace this two GS110tp Switches with routers.
    • schumaku's avatar
      schumaku
      Well, a router might help to drive another media type - but probably not in this case, unless you are going to use some other technology for the longer distance.
      Better approach would be to migrate the longer distance links to some inexpensive fiber some Multi Mode Fiber does drive GbE over up to 1000 meters or 10GbE on up to 550 meters.
    • schumaku's avatar
      schumaku
      Of course you can. However, for Ethernet the max reach is always 100 meters for 10/100/1000/1GBASE-T.  Using fiber much more. Your schema does not show an length exceeding 90 meters resp. 80 meters per hop, what would be fine. If there are 170 meters, the cabling and patching is not as per the drawing..
      The length of the cables and amount of switches caused packet collisions.
      Of course, if the Ethernet links exceed 100 meters, troubles start on the link. For this you don't need Wireshark or any other rocket science.
      The problem was solved by inserting routers.
      Still don't see why a router. You want to build some continous L2 network, so why add routing along the ines is beyond me. Correct way to mitigate copper cable lengs > 100 meters would be the installtion of fiber. Alternate, you can add a L2 switch along the line..
      On top of all that, it's a good rule when it comes to STP you should not exceed 7 hops for any connection, so the spanning-tree algorithm has enough time to converge.
ProSupport for Business
