Stenley
Oct 03, 2021Follower
Low upload speed when device connect to managed switch, download speed is ok
I have four netgear switch. Two are managed switch, another are unmanaged switch.
My home use ATT fiber. Download speed up to 1200 Mbps, Upload speed up to 1000 Mbps.
My question is when devices connect to unmanaged switch like XS505M & GS110MX. The device can run full speed both download and upload.
When Device connect to managed switch like MS510TX & MS510TXM. The device only can run full download speed. The upload speed only around 300 Mbps.
I just connect with original setting. So I don't know what's happened.
1 Reply
- DaneANETGEAR Employee Retired
What is the current firmware version of your MS510TX and MS510TXM switches? If ever its not yet the latest version, I suggest you to update it then check if the same problem will occur.
You can download the latest firmware version for the MS510TX here.
You can download the latest firmware version for the MS510TXM here.
DaneA
NETGEAR Community Team
