× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Error checking for internet updates
fedtmule25
Hi All
Im new into this business, and don´t know a lot about NAS, so could anybody please help me.
When I try to check for updates I get this answer "error checking for internet updates".
I need to get the updates, so I can get it to work with my Itunes.
Thanks in advance
Message 1 of 8
robyb
Re: Error checking for internet updates
fedtmule25 wrote:
Hi All
Thanks in advance
Do a re-flash (see sticky), it will bring you to the latest update.
Cheers,
Roby!
Message 2 of 8
fedtmule25
thanks I´ve done that, now it works, but a new problem came up. I´ve lost access to stora.
I can see stora under network, and in itunes, but lost contact and I don´t know what to do.
When I put a new user in, the same problem occure - it´s not possible to enter the folders..
Can anybody help me.
regards
Message 3 of 8
robyb
Are you able to login from mystora.com using your admin account?
Cheers,
Roby!
Message 4 of 8
fedtmule25
yes, no problem.
Is it possible to make af formating of the entire disk, create new account, and it will work then.
I don´t have that many data on the disk, and nothing important, so if you think that will get it to work it will be ok for me.:)
thanks
Message 5 of 8
robyb
You can format the disk from Preferences -> Disk management.
Cheers,
Roby!
Message 6 of 8
fedtmule25
hi
I did a format, then a reflash, and now I have acess to all my folders and it works in itunes as well - so eveything is fine
thanks
Message 7 of 8
hoppo1
Tutor
I find that with a static IP the DNS settings go astray and that results in this error. It might be worth checking your network settings before flattening the stora if it happens again.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 6431 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
