× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Raid 1 Single Disc
frogger55
Raid 1 Single Disc
Hi,
My Stora has been happily chugging away for a few years now, however when looking in prefernces - disc management I can only see one disc listed ( I have 2 as configured as raid 1). Both lights are green on the outside and there's no indication as to which disc is visible and which isn't (escept the lower area under disc preferences is blank, so guessing tray 1 is OK)
Can anyone give advice as to what may be happening? Would a reflash help?
Thanks for any help/advice
Message 1 of 3
nhann
NETGEAR Employee Retired
Re: Raid 1 Single Disc
Hi frogger55,
You can check for disk failture by following this link: http://kb.netgear.com/app/answers/detail/a_id/21531/~/how-can-i-verify-that-my-disk-is-bad%3F
Please try reflashing your stora. You can also find a discussion relating to your issue here, for more troubleshooting steps: https://community.netgear.com/t5/Stora-Legacy/RAID1-Single-Disk-Disk-2-disappears/td-p/446656
I look forward to hearing from you.
NhanN
Message 2 of 3
frogger55
Thanks for the advice.
From reading the thread it seems most likely the drive is failing. Will try a re-flash and see how it goes first.
Cheers,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4572 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
