× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Where has mystora.com gone
JOB019
Can't change the configuration of any of my stora boxes because www.mystora.com does not exist any more.
Help
Message 1 of 4
kohdee
NETGEAR Expert
Re: Where has mystora.com gone
MyStora is back up. Can you confirm for us that your systems can reconnect to Stora servers?
Message 2 of 4
JOB019
Thanks for putting mystora.com back up.  What was the problem?
There is still a problem, I get the error message as follows -
Your connection is not private
Attackers might be trying to steal your information from www.mystora.com (for example, passwords, messages or credit cards) NET::ERR_CERT_WEAK_SIGNATURE_ALGORITHM
I feel it is not safe to use as it may be giving access to my stora boxes or passwords.
Will you be able to fix it?
Message 3 of 4
mdgm-ntgr
NETGEAR Employee Retired
We've taken over the server from a 3rd party. See this post
We're looking into the certificate issue. Anyway the certificate is expiring soon so it would have needed to be renewed regardless. We're not able to update the Stora software (this hasn't been updated for quite some time now) so there will likely be some limits on the quality of certificate we're able to use without breaking the mystora.com service.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3234 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
