- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
A6100 dropouts!
- Mark as New
- Bookmark
- Subscribe
- Permalink
A6100 dropouts!
I have a 5G wireless broadband, and the adapter keeps loosing the internet connection. Very annoying, and often hard to regain connection. It seems to remain on the network, but with no internet. I know its the adapter, because i can switch back to my internal wifi-card, and the connection reassumes. I have a theory that it might happen mostly when im doing heavy internet tasks, like downloading larger files or streaming from netflix, but i cant say im certain about that.
Latest drivers. Running windows 10. Doesnt matter what USB port i use, it happens either way.
Does anyone have a proper theory on this? Is the adapter simply broken?
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A6100 dropouts!
Hi Upnorth,
Uninstall the drive and reinstall it using the standalone driver. Observe the connection and report back if same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A6100 dropouts!
Hi Upnorth,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A6100 dropouts!
I am also having this issue on multiple PC running windows 10 build 14393.5 which is the latest build. running non-standalone 1.0.0.32 driver and genie.
I will uninstall the the full version and install the standalone version to see what happens.
Bob
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A6100 dropouts!
After uninstalling the full A6100 1.0.0.32 and installing the A6100 1.0.0.32 standalone drivers and started an Acronis partion backup, the A6100 dropped off after a minute or two!
Bob
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A6100 dropouts!
This is a known problum that Netgear can not figure out .it is the same driver as the A6210.... There driver is an Old one before the windows updates .....They have NOT made a new driver AT ALL for this device. .... I have been going around and around for 2 months with the Level 2 suport on this .... And JameGL all the fix's you ty to have customers do will not solve this issue.... Netgear needs to update the driver as a company like Alpha has that runs the same same chipset ....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A6100 dropouts!
I'm having this issue too, and it's getting a little old.
