× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Need to replace old linksys adapter with compatible NG one for my R8000 router
cybergrrl
I just switched routers and modems from Linksys to NG and now have a nice Nighthawk R8000 but completely forgot my desktop still has a Linksys AE2500 wireless adapter from ages ago. It's working ok so far and the desktop is running Win7 but will soon be upgraded to Win10.
I'm assuming, for several reasons, I really should upgrade the adapter. What's the best NG adapter to compliment the R8000 on a 9yo Dell desktop?
TIA - cybergrrl
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
Accepted Solutions
Guru
Re: Need to replace old linksys adapter with compatible NG one for my R8000 router
You can update the adapter if you want. But if its doing everything you want it to, it isn't necessarily needed.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1011 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
