× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNCE2001 – Universal WiFi Internet Adapter GREEN light blinking
PapaBerg
Follower
Helo TO ALL!!!
     This is my first QUESTION....Be understanding please. I have had this adapter for sometime, its always worked.. Power surged- NOW Blinking green light? Tried
1. Totally un-plugging power source, from wall and unit.  NO RESULTS
2. Reset with PIN. No RESULTS
3. Un-plugged everything for 1 HR. NO RESULTS
Simple help will be welcome, THANKS!!!!
Model: WNCE2001|Universal WiFi Internet Adapter|EOL
Message 1 of 2
Guru
Re: WNCE2001 – Universal WiFi Internet Adapter GREEN light blinking
Power surges are great at killing electronics. Its a bit older of an adapter but I did find someone that had the issue and was able to fix it via tftp. Read this post as it has great tips on how the user fixed their device.
https://community.netgear.com/t5/WiFi-Adapters/WNCE2001-power-led-blinking-green-and-no-connection/t...
If you use windows 10, it has a built in windows tftp client that you just need to enable.
https://www.thewindowsclub.com/enable-tftp-windows-10
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1054 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
