× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
how to get a6100 running on fedora KDE
modab
Follower
how do you get ac600 running on fedora kde? nothing has worked and I can't just use this old 80s belkin adapter (it can't run a thing except this forum)
Message 1 of 2
Guru
Re: how to get a6100 running on fedora KDE
The A6100 is only supported on windows 10.
If you wanted to get it working on fedora, you might ask on their forums for help getting it running.
It uses a realtek rtl8811au chipset
there might be generic drivers on fedora for installing that
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 596 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
