GaACETech's avatar
Jan 24, 2016
Need PoE Passive Switch - Passive for Unifi AP at 24V
I purchased 6 of the Ubiquiti Access Points with the Netgear GS728TP managed switch
- need the 4 ports for fiber
- need PoE ports for the Access Points (APs)
Come to find out the Unifi APs are passive PoE 24V.  The GS728TP is not passive.
The Question:
Is there a Netgear passive PoE switch?  8 port would suffice
Thanks,
Darryl
  • Hi GaACETech,
    I am afraid to inform that NETGEAR does not have passive PoE switches.  Not sure if this will help, however, let me share this forum link I found online.
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi GaACETech,
    DaneA
ProSupport for Business
