rt_677223
Feb 23, 2023Follower
GS308EPP with passive PoE device?
I'm looking for a PoE switch to power a couple of devices in my home. I want to by the GS308EPP (123w) Netgear Switch. Now I'm dragged into the PoE rabbit hole and not sure about what's possible and what's not.
One my devices is a UniFi Access Point AC Lite with these PoE specs:
- Power Method Passive PoE (Pairs 4, 5+; 7, 8 Return)
- Power Supply 24V, 0.5A Gigabit PoE Adapter*
- Max. Power Consumption 6.5W
Is this a compatible combination? Or will the GS308EPP blow up the device?
Who can help?
1 Reply
The GS308EPP won't blow up your Passive "PoE" device, but can't power it either. If you decide adding a power injector matching this passive PoE device, double check it's after (upstream), between the switch and the AP.
