Orbi WiFi 7 RBE973
Reply
Cannot Factory Reset ProSafe GS108
FigLeaf
hello everyone,
I am having a hard time resetting my ProSafe 8 ports Gigabit Switch (GS108). I can't find the reset button anywhere.
I cannot find the IP address using the SmartWizard Discovery tool either.
What can I do to get this switch up and running?
Thanks for the help. 🙂
Model: GS108|Gigabit Switches
Message 1 of 5
Accepted Solutions
schumaku
Guru
Re: Cannot Factory Reset ProSafe GS108
No IP assigned at all, no management access of any kind.
Message 4 of 5
All Replies
schumaku
Guru
That's a little bit difficult because of this GS108 is a non-managed switch - noting to reset.
What's the problem with it?
Message 2 of 5
FigLeaf
oh I see. When you say it is an unmanaged switch, there is no way I can open the browser page for it right? So it will always be given an IP address by the DHCP?
I wanted to set a static IP address for it that's all.
Message 3 of 5
schumaku
Guru
Message 4 of 5
FigLeaf
Perfect!!! Thanks a lot @schumaku  for the orientation.
The switch works well. I have it running right now. No static IP though; but I guess that's okay.
I never would have thought it was an unmanaged switch 'cause I don't know much about switches. I am quite new to networking and it has is a learning curve, but I intend to keep gaining more knowledge from others as well.
Thanks again man. Bless up.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 16299 views
  • 0 kudos
  • 2 in conversation
Announcements
