Orbi WiFi 7 RBE973
Reply
GS608v4 - Firmware Update?
Confused_in_ID
Is there or is there not a firmware update to the NetGear GS608v4? I have an email message from NetGear urging me to updat the firmware; the website seems to say there isn't one for that model.
TIA.
Model: GS608v4|Unmanaged Switch
Message 1 of 4
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: GS608v4 - Firmware Update?
@Confused_in_ID,
You're welcome! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 4 of 4
All Replies
JohnC_V
NETGEAR Moderator
Hi Confused_in_ID,
Welcome to our community!
GS608v4 is an unmanaged switch. It is just a plug and play device and it doesn't have any GUI.
You may check the reference here.
Message 2 of 4
Confused_in_ID
Thanks, JohnCarloV. Thought so but confused by the email.
Message 3 of 4
JohnC_V
NETGEAR Moderator
@Confused_in_ID,
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2413 views
  • 0 kudos
  • 2 in conversation
Announcements
