fanOinfrant's avatar
Dec 30, 2014
AFP Speed crashes after 6.2.0+ upgrade
I was on 6.1.2 with everything running pretty great. When I upgraded to 6.2.1 and then 6.2.2, AFP speeds were AWFUL, and getting into directories and files was so slow that Finder would often time out. SMB speeds were unaffected. I suspected it might be because of Netatalk updates and sure enough, THIS command worked for me, which has to be run on each share:
dbd -ftv -u myuser /data/GigRAID25/ > /tmp/Gigdbdfix.txt&
You can run:
dbd -s /data/GigRAID25/
To CHECK that the index is corrupted. I would get output like the following in my runs:
Bad CNID in adouble file of '/data/GigRAID25/Backups/Games/Hi-Rez_Studios/games/tribes alpha/TribesGame/CookedPC/TribesGame.u'
Dec 29 18:30:06.931498 dbd[4843] {cnid_dbd.c:572} (debug:CNID): cnid_dbd_add: CNID: 56695, name: 'TribesGame.u', dev: 0x1e, inode: 0xd6050, type: file
Dec 29 18:30:07.023871 dbd[4843] {cnid_dbd.c:583} (debug:CNID): cnid_dbd_add: got CNID: 56726
CNID mismatch for '/data/GigRAID25/Backups/Games/Hi-Rez_Studios/games/tribes alpha/TribesGame/CookedPC/TribesGame.u', CNID db: 56726, ad-file: 0
Bad CNID in adouble file of '/data/GigRAID25/Backups/Games/Hi-Rez_Studios/games/tribes alpha/TribesGame/CookedPC/GameFramework.u'
Dec 29 18:30:07.024231 dbd[4843] {cnid_dbd.c:572} (debug:CNID): cnid_dbd_add: CNID: 56695, name: 'GameFramework.u', dev: 0x1e, inode: 0xd6051, type: file
Dec 29 18:30:07.120233 dbd[4843] {cnid_dbd.c:583} (debug:CNID): cnid_dbd_add: got CNID: 56727
CNID mismatch for '/data/GigRAID25/Backups/Games/Hi-Rez_Studios/games/tribes alpha/TribesGame/CookedPC/GameFramework.u', CNID db: 56727, ad-file: 0
Bad CNID in adouble file of '/data/GigRAID25/Backups/Games/Hi-Rez_Studios/games/tribes alpha/TribesGame/CookedPC/OnlineSubsystemPC.u'
Dec 29 18:30:07.120396 dbd[4843] {cnid_dbd.c:572} (debug:CNID): cnid_dbd_add: CNID: 56695, name: 'OnlineSubsystemPC.u', dev: 0x1e, inode: 0xd6052, type: file^C
Dec 29 18:30:07.201627 dbd[4843] {cnid_dbd.c:583} (debug:CNID): cnid_dbd_add: got CNID: 56728
CNID mismatch for '/data/GigRAID25/Backups/Games/Hi-Rez_Studios/games/tribes alpha/TribesGame/CookedPC/OnlineSubsystemPC.u', CNID db: 56728, ad-file: 0
Bad CNID in adouble file of '/data/GigRAID25/Backups/Games/Hi-Rez_Studios/games/tribes alpha/TribesGame/CookedPC/Lang_English.dat'
Dec 29 18:30:07.201941 dbd[4843] {cnid_dbd.c:572} (debug:CNID): cnid_dbd_add: CNID: 56695, name: 'Lang_English.dat', dev: 0x1e, inode: 0xd6053, type: file
Dec 29 18:30:07.320232 dbd[4843] {cnid_dbd.c:583} (debug:CNID): cnid_dbd_add: got CNID: 56729
ProSupport for Business
