dh1760's avatar
dh1760
Connecting iscsi disk to CentOS 6.5 system
For testing purposes, I created a LUN group, set authentication open (no CHAP), and am following the steps outlined in https://ezunix.org/index.php?title=Connect_to_an_iSCSI_Volume_with_RedHat,_Fedora_or_CentOS_Linux to configure and initiate the disk. Everything flows as outlined until restarting /etc/init.d/iscsi to attach the drive. The restart stalls and I can see repeated log entries of "May 26 09:43:00 uka4-ob iscsid: connect to 192.168.168.252:3260 failed (Connection refused)" until I ctrl-c to stop the script.
I was able to discover the LUN groups using "iscsiadm -m discovery -t sendtargets -p 192.168.168.252", so it seems like connections should be accepted (assuming discovery happens on the same port 3260 as connections). I have CHAP disabled on the readyNas LUN group and CHAP username/password commented in iscsid.conf.
Any advice or assistance would be greatly appreciated.
  • A bit more info: the readyNas has 2 network interfaces on 192.168.1.0.24 and 192.168.168.0/24. I am attempting this connection via the 192.168.1.0/24 interface (target address is 192.168.1.252), as that is on the same network as the client. The discovery reported the 2 target groups via each interface:
    192.168.168.252:3260,1 iqn.1994-11.com.netgear:ngnas1:a901f7d2:group1
    192.168.1.252:3260,1 iqn.1994-11.com.netgear:ngnas1:a901f7d2:group1
    192.168.168.252:3260,1 iqn.1994-11.com.netgear:ngnas1:fbc542ca:group2
    192.168.1.252:3260,1 iqn.1994-11.com.netgear:ngnas1:fbc542ca:group2
    I set the node login to the group2 target via the 192.168.1.252:3260 portal, however the "connection refused" messages are being reported as coming from the other (192.168.168.252) interface. It looks like the problem is that when restarting iscsi, the connection is being attempted via the wrong interface.
    [root@uka4-ob ~]# iscsiadm --mode node iqn.1994-11.com.netgear:ngnas1:a901f7d2:group1 --portal 192.168.1.252:3260 --login
    [root@uka4-ob ~]# /etc/init.d/iscsi restart
    Stopping iscsi: [ OK ]
    Starting iscsi: iscsiadm: Could not login to [iface: default, target: iqn.1994-11.com.netgear:ngnas1:fbc542ca:group2, portal: 192.168.168.252,3260].
    iscsiadm: initiator reported error (8 - connection timed out)
    iscsiadm: Could not login to [iface: default, target: iqn.1994-11.com.netgear:ngnas1:a901f7d2:group1, portal: 192.168.168.252,3260].
    iscsiadm: Could not log into all portals
    Is there a way for me to configure the system so that it only tries to login to the portal that I specify?
  • Figure it out... I had mistakenly connected 2 nodes, one for the (wrong) portal on 192.168.168.252 and the other on the (correct) portal 192.168.1.252.
ProSupport for Business
