stevevandegaer2's avatar
Aug 11, 2019
Disk test running 10 days already
Hello,
I'm running a readynas with firmware 6.10.1
On august 1 I started a disk test and it is still running now on the 11th.
I guess this isn't normal. What should I do? Is it safe to reboot?
Kind regards
Steve
  • Last night had to reboot after the device became unresponsive when I activated file search.
    Should I try the disk test again or do something else first?
    • StephenB's avatar
      One possible reason for the very long test time is that you might have a failing disk.  I suggest downloading the log zip file and looking in disk_info.log.  Also look for disk related errors in kernel.log
      You might also want to use ssh, and run smartctl -x
      • Not seeing any error in either log file.
        Started the disk check again, hoping I will get some result this time
ProSupport for Business
