Reply
Highlighted
Re: Easy fix fan/temp OS6 issues on x86 legacy #no support
no luck Smiley Sad had to stop fancontrol manually
Wed Nov 27 2013 0:31:32	Disk: Disk in channel '3' (Internal) exceeded safe temperature threshold (61 C).
Wed Nov 27 2013 0:31:31 Disk: Disk in channel '2' (Internal) exceeded safe temperature threshold (63 C). Wed Nov 27 2013 0:29:35 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (405 rpm). Wed Nov 27 2013 0:29:24 Disk: Disk in channel '5' (Internal) exceeded safe temperature threshold (61 C). Wed Nov 27 2013 0:29:23 Disk: Disk in channel '3' (Internal) exceeded safe temperature threshold (60 C). Wed Nov 27 2013 0:29:22 Disk: Disk in channel '1' (Internal) exceeded safe temperature threshold (61 C). Wed Nov 27 2013 0:28:06 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (402 rpm). Wed Nov 27 2013 0:27:14 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (498 rpm). Wed Nov 27 2013 0:27:12 Disk: Disk in channel '2' (Internal) exceeded safe temperature threshold (62 C). Wed Nov 27 2013 0:25:36 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (403 rpm). Wed Nov 27 2013 0:25:04 Disk: Disk in channel '2' (Internal) exceeded safe temperature threshold (61 C). Wed Nov 27 2013 0:23:48 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (485 rpm). Wed Nov 27 2013 0:23:07 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (481 rpm). Wed Nov 27 2013 0:22:56 Disk: Disk in channel '2' (Internal) exceeded safe temperature threshold (60 C). Wed Nov 27 2013 0:21:40 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (500 rpm). Wed Nov 27 2013 0:21:09 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (502 rpm). Wed Nov 27 2013 0:18:51 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (401 rpm). Wed Nov 27 2013 0:17:35 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (403 rpm). Wed Nov 27 2013 0:16:43 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (491 rpm). Wed Nov 27 2013 0:12:40 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (493 rpm). Tue Nov 26 2013 23:54:14 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (543 rpm). Tue Nov 26 2013 23:50:11 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (456 rpm).Tue Nov 26 2013 23:36:41 System: Fan 'Fan' in enclosure 'Internal' speed is below threshold. (500 rpm).
Message 76 of 172
Highlighted
Have you installed sensors.d file conf as described in this post http://www.readynas.com/forum/viewtopic.php?f=51&t=71155&start=60#p411650 ?
Are you able to see on frontview the speed of your ultra6 fan ?
Did you change the fan or is it regular fan ? fancontrol values are different for each fan.
You can see 400 or 500 rpm as fan speed in this nas log. it's not enough .... With regular fan, speed would be 850 rpm minimum to keep cold the ultra6 enclosure.
Tune your fancontrol file to have 850 rpm minimum
Message 77 of 172
Highlighted
Hi glem,
thanks again for the help!
* yes I installed sensors.d file conf as suggested
* yes I'm able to see on frontview the speed of my ultra6 fan
* it is a regular fan
how I can tune fancontrol file to have 850 rpm minimum ? here my fancontrol file:
# Configuration file generated by pwmconfig, changes will be lost
INTERVAL=10
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/it87.2576
DEVNAME=hwmon0=coretemp hwmon1=it8721
FCTEMPS=hwmon1/device/pwm3=hwmon0/device/temp2_input
FCFANS= hwmon1/device/pwm3=hwmon1/device/fan3_input
MINTEMP=hwmon1/device/pwm3=51
MAXTEMP=hwmon1/device/pwm3=58
MINSTART=hwmon1/device/pwm3=50
MINSTOP=hwmon1/device/pwm3=50
MINPWM=hwmon1/device/pwm3=50
MAXPWM=hwmon1/device/pwm3=255
Best regards
G
Message 78 of 172
Highlighted
upgrade pwm3 values : for example try 70, and after 75, 80 ....
change these lines in /etc/fancontrol file
MINSTART=hwmon1/device/pwm3=70
MINSTOP=hwmon1/device/pwm3=70
MINPWM=hwmon1/device/pwm3=70
and then execute this command to override fancontrol daemon
/etc/init.d/fancontrol restart
look on frontview the speed fan ... and try again
You can also run pwmconfig (as described in the second post of this topic) to look at concordance between pwm3 values and fan speed
Message 79 of 172
Highlighted
I installed OS6 on my old version ReadyNAS Pro 6350 (MB version is Flame 6 Ver 1.1) and all works fine except that in Frontview both the fans constantly show as running at 5355RPM and Temps are as follows Aux 40degC CPU 43degC and System 40DegC
Fans seem to be working normally but the speeds are not being reported properly. Not sure about the temps at the moment.
Any tips?
Cheers
Message 80 of 172
Highlighted
Did you install 6.0.x or 6.1.x ? if you have 6.0.x, update first to 6.1.x and check reports.
If all fans and temps seem to be working fine, you have just to add a sensors.d config file to compute the real values in fan and temp input expected by frontview.
Use this example working on ultra6 model to define your own config file. http://www.readynas.com/forum/viewtopic.php?f=51&t=71155&start=60#p411650
- chip statement is the name of your chip
- compute statement : example: compute fan1 0+fan3_input,0-fan3_input
The first argument (fan1) is the feature name. The second specifies how the raw value must be translated to the real-world value (0+fan3_input); The third specifies how the real-world value should be translated back to the raw value (0-fan3_input)
Find in the folder /sys/devices/platform/it8.... or w... or i8... (depend of your chipset) the files temp(x)_input and fan(x)_input which report your box values and use compute statements to put these values in the files expected by OS6 (files are not modified, changes affect only memory).
Message 81 of 172
Highlighted
Glem,
I have the old version rndp6350 - will you guide me on what file I need to add in sensors.d? I suppose the ultra version is different to mine as adding the file did nothing. I even renamed it to rndp6000.conf.
Also do I need to refer to this file from anywhere else?
I have latest 6.1.4.
Sorry to be such a noob, but where do I find the name of my chip? The folder with teh fan and temps is w83627ehf.2576 on mine.
I also noticed that the temperature graph is blank.
Cheers
Message 82 of 172
Highlighted
Re: Easy fix fan/temp issues on OS6 legacy #no support
ATCIS wrote:
In case anyone cares. . . I finally got the graph working!
As it turns out it was likely a permissions problem ALL ALONG Smiley Surprisedops:
Still something not quite right though. I just checked the ambient room temperature which is approximately 82 degrees F. How can the CPU temperature be 79 degrees F? As I watch the graph over time both temperatures are dropping slightly every minute. The System temperature seems reasonable. It is currently 97 degrees F. I'll keep an eye on things for a while and report back later. . .
I've been trying to get the graphs I've generated embedded in the performance tab but can't see which file it's rendered from. How did you manage to do it? :shock:
Message 83 of 172
Highlighted
Tutor
Perhaps we could give you a bit of guidance if you shared with us the platform you are trying to get this working on?
Message 84 of 172
Highlighted
Can someone help me out please?
My frontview temp readings are not OK.
My fans work fine but are not showing up correct in frontview.
output of the sensors are:
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +44.0°C (high = +84.0°C, crit = +100.0°C)
Core 1: +46.0°C (high = +84.0°C, crit = +100.0°C)
Core 2: +42.0°C (high = +84.0°C, crit = +100.0°C)
Core 3: +42.0°C (high = +84.0°C, crit = +100.0°C)
w83627dhg-isa-0a10
Vcore: +1.14 V (min = +0.00 V, max = +1.74 V)
in1: +1.87 V (min = +0.54 V, max = +0.89 V) ALARM
AVCC: +3.22 V (min = +2.98 V, max = +3.63 V)
+3.3V: +3.20 V (min = +2.98 V, max = +3.63 V)
in4: +1.23 V (min = +1.14 V, max = +0.64 V) ALARM
in5: +1.49 V (min = +1.14 V, max = +1.18 V) ALARM
in6: +1.02 V (min = +1.70 V, max = +1.66 V) ALARM
3VSB: +3.18 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.12 V (min = +2.70 V, max = +3.63 V)
fan1: 1222 RPM (min = 28125 RPM, div = 16) ALARM
fan2: 1814 RPM (min = 1467 RPM, div = 8)
fan3: 1132 RPM (min = 733 RPM, div = 8)
fan4: 0 RPM (min = 2109 RPM, div = 128) ALARM
fan5: 0 RPM (min = 878 RPM, div = 128) ALARM
temp1: +58.0°C (high = -1.0°C, hyst = +125.0°C) sensor = thermistor
temp2: +33.0°C (high = +80.0°C, hyst = +123.0°C) sensor = CPU diode
temp3: -47.0°C (high = +80.0°C, hyst = +123.0°C) sensor = thermistor
cpu0_vid: +0.000 V
And there is no file rndu6000.conf in etc/sensors.d/, only rn2120.conf with the following text:
chip "g760a-i2c-*-3e"
label fan1 "fan1"
chip "g760a-i2c-*-48"
label fan1 "fan2"
chip "g760a-i2c-*-49"
label fan1 "fan3"
So i've added the line to that file:
chip "it8721-isa-0a10"
compute temp2 0+temp1_input,0-temp1_input
Stil the same story.. I even added the file rndu6000.conf to the folder with the text above without any luck.
My fan control file is from the PRO6, al the other settings fail and cause my CPU fan to max out on RPM.
INTERVAL=10
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/w83627ehf.2576
DEVNAME=hwmon0=coretemp hwmon1=w83627dhg
FCTEMPS= hwmon1/device/pwm2=hwmon1/device/temp2_input hwmon1/device/pwm1=hwmon1/device/temp1_input
FCFANS= hwmon1/device/pwm2=hwmon1/device/fan2_input hwmon1/device/pwm1=hwmon1/device/fan1_input
MINTEMP= hwmon1/device/pwm2=30 hwmon1/device/pwm1=55
MAXTEMP= hwmon1/device/pwm2=60 hwmon1/device/pwm1=60
MINSTART= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MINSTOP= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MINPWM= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MAXPWM= hwmon1/device/pwm2=200 hwmon1/device/pwm1=80
Any help would be great!
Message 85 of 172
Highlighted
I'm trying to get the graphs on a RN102 and RN104 with OS 6.1.5
Message 86 of 172
Highlighted
Tutor
Graphs on the RN102 and RN104?
Hmmm. . . I must be missing something here. I thought that both the RN102 and RN104 models shipped with OS6 out of the box. Shouldn't ALL the graphs and other graphical elements be working correctly without the need to perform any of the hacks that those of us who are running OS6 on legacy hardware? I'm confused. . . :-?
Message 87 of 172
Highlighted
Guru
The RN102/RN104 are OS6 only.
You can see the picture in the "performance" tab. However, the graphs are not available on the RN1xx. Per the manual:
Note: Status graphics are not supported for ReadyNAS 102 and 104 systems.
I'm not sure why this limitation is there, but I wish it weren't.
Message 88 of 172
Highlighted
So are all the graphs available on the higher models, or is it a hack to get them showing in all models?
Message 89 of 172
Highlighted
Guru
I know of no hack, and I think all the people who have shown the graphs are running the x86 OS6 binary (RN3xx/RN611/ultra/pro).
Message 90 of 172
Highlighted
Hmm, I wonder where the code that renders the front page is stored... If anyone has any info. I'd be very appreciative, else I'll have to look into it after my last exam!
Message 91 of 172
Highlighted
Tutor
Unbelievable. . . Why would someone sell a product that was less than 100% functional right out of the box (and at least 8 firmware updates later)? Especially considering that a legacy device such as the Ultra 4 is about 90% functional without requiring any hard core hacking. I just don't get it. . .
Message 92 of 172
Highlighted
NETGEAR Employee Retired
The resources required for the graphics might put too much load on low powered systems such as the 102/104.
Message 93 of 172
Highlighted
Tutor
Interesting hypothesis. Just curious, by that do you mean while someone is actually viewing the Performance page in the Web GUI, or generating the historical data in the background?
Unfortunately I don't know much about the Marvell Armada 370, but in theory, how does it compare (performance wise) to an Intel Atom D410 CPU like the one found in the Ultra 4? I am consistently amazed at how much work that single core low power CPU can perform. Mine pulls and processes six H.264 video streams (from surveillance cameras) 24/7/365, and the CPU utilization rarely peaks over 50% utilization. Considering how much (perhaps I should have said "how little") it cost me, I must say I couldn't be happier with it. :-D
Message 94 of 172
Highlighted
Intel CPUs even the one in the Ultra 4 are much faster than the Marvell Armada 370-and the Ultra 4 has double the RAM of the 102/104.
Message 95 of 172
Highlighted
Tutor
Wow, fascinating stuff. I must say mdgm, the wealth of information that you possess never fails to amaze me Smiley Happy
Message 96 of 172
Highlighted
Guru
If someone were to post a how-to with instructions on installing a performance benchmark program on the various ReadyNAS, I think it there would be enough interest to get results from most (if not all) of the platforms.
Message 97 of 172
Highlighted
Hi guys,
I have now taken the plunge and installed OS6 on my Pro, however, I really need some guidance in terms of stabilising my fan control speeds as well as getting the temp graphs to work.
Thus far I have ready the forum posts and have done the following:
Step 1
apt-get update && apt-get upgrade
apt-get install lm-sensors fancontrol
echo "#fancontrol" > /etc/fancontrol
Step 2
Used the powerconfig command as suggested http://www.readynas.com/forum/viewtopic.php?f=51&t=71155#p395324
Step 3
/etc/init.d/fancontrol stop
/etc/init.d/fancontrol start
Here is the output after sensors:
root@READYNASPRO:/sys/devices/platform/coretemp.0# sensors
coretemp-isa-0000
Core 0: +27.0 C (high = +84.0 C, crit = +100.0 C)
Core 1: +27.0 C (high = +84.0 C, crit = +100.0 C)
Core 2: +21.0 C (high = +84.0 C, crit = +100.0 C)
Core 3: +21.0 C (high = +84.0 C, crit = +100.0 C)
w83627dhg-isa-0a10
in1: +1.74 V (min = +0.84 V, max = +1.89 V)
AVCC: +3.20 V (min = +2.98 V, max = +3.63 V)
in4: +1.22 V (min = +0.38 V, max = +1.32 V)
in5: +1.49 V (min = +0.09 V, max = +0.30 V) ALARM
in6: +1.02 V (min = +0.95 V, max = +1.05 V)
3VSB: +3.17 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.07 V (min = +2.70 V, max = +3.63 V)
fan1: 1004 RPM (min = 42187 RPM, div = 8) ALARM
fan2: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan3: 3125 RPM (min = 3375 RPM, div = 8) ALARM
fan4: 0 RPM (min = 5273 RPM, div = 128) ALARM
fan5: 0 RPM (min = 10546 RPM, div = 128) ALARM
temp1: +46.0 C (high = +127.0 C, hyst = +125.0 C) sensor = thermistor
temp2: +24.5 C (high = +80.0 C, hyst = +123.0 C) sensor = CPU diode
temp3: +19.5 C (high = +80.0 C, hyst = +123.0 C) sensor = thermistor
cpu0_vid: +0.000 V
Fancontrol file
#fancontrol
INTERVAL=10
I have modded by Pro with a q6600.
Any help would be appreciated.
NAS Product 1: ReadyNAS Pro 6 8192 MB [6-6-6-18 DDR2]
RAIDiator Version: RAIDiator-x86 Version: 6.2.4
RAID Configuration: RAID Level X-RAID (Single Redundancy)
Hard Disk Brand, Model, Capacity & Number: Seagate ST31000524NS 1TB x 6
ReadyNAS Security Mode: User
NAS Product 2: ReadyNAS Pro 3968 MB [4-5-5-15 DDR2]
RAID Configuration: RAID Level X-RAID2 (Single Redundant)
Hard Disk Brand, Model, Capacity & Number: Seagate ST31000528AS 1TB x 6
Network Router/Switch/UPS: Nighthawk R7000, Netgear GS108T, APC Back-UPS RS 1200 LCD
Computers: Sony VAIO VPCF11C53-FZ21Z/Core i7 Q720 1.6 GHZ/8 gb ram/500gb Seagate/Windows 7 Ultimate
Shuttle XPC SX58J3/Core i7 980x Extreme Edition 3.33 GHZ /16 gb ram/256gb SSD OCZ/Windows 7
Macbook Pro 15" Retina/Core i7 4850-HQ 2.3 GHz/16gb ram/512gb SSD PCIe/OSX Mavericks
"I don't suppose I could convince you to come up here and fight like a spider?" - Spider Man
Message 98 of 172
Highlighted
Update!
I have graphing in Frontview and have been able to regulate my fans.
Here is the lm-sensors vs the Frontview readings for the fans:
Output from lm-sensors OS6
coretemp-isa-0000
Core 0: +39.0 C (high = +84.0 C, crit = +100.0 C)
Core 1: +40.0 C (high = +84.0 C, crit = +100.0 C)
Core 2: +31.0 C (high = +84.0 C, crit = +100.0 C)
Core 3: +32.0 C (high = +84.0 C, crit = +100.0 C)
w83627dhg-isa-0a10
Vcore: +1.19 V (min = +0.00 V, max = +1.74 V)
in1: +1.73 V (min = +0.84 V, max = +1.89 V)
in5: +1.49 V (min = +0.09 V, max = +0.02 V) ALARM
in6: +1.02 V (min = +0.94 V, max = +1.04 V)
fan1: 1180 RPM (min = 10546 RPM, div = 8) ALARM
fan2: 0 RPM (min = 5273 RPM, div = 128) ALARM
fan3: 2311 RPM (min = 831 RPM, div = 8)
fan5: 0 RPM (min = 1054 RPM, div = 128) ALARM
temp1: +49.0 C (high = +127.0 C, hyst = +125.0 C) sensor = thermistor
temp2: +35.0 C (high = +80.0 C, hyst = +123.0 C) sensor = CPU diode
temp3: +18.5 C (high = +80.0 C, hyst = +123.0 C) sensor = thermistor
cpu0_vid: +0.000 V
OS 4.2.25
Fan SYS	912 RPM		OK
Fan CPU 2057 RPM
Fancontrol file for Pro
INTERVAL=10
FCTEMPS=hwmon1/device/pwm3=hwmon0/device/temp2_input hwmon1/device/pwm1=hwmon1/d
FCFANS=hwmon1/device/pwm3=hwmon1/device/fan3_input hwmon1/device/pwm1=hwmon1/dev
MINTEMP=hwmon1/device/pwm3=20 hwmon1/device/pwm1=10
MAXTEMP=hwmon1/device/pwm3=65 hwmon1/device/pwm1=25
MINSTART=hwmon1/device/pwm3=28 hwmon1/device/pwm1=16
MINSTOP=hwmon1/device/pwm3=26 hwmon1/device/pwm1=14
MINPWM=hwmon1/device/pwm3=16 hwmon1/device/pwm1=14
MAXPWM=hwmon1/device/pwm3=28 hwmon1/device/pwm1=22
I have done various tests and can report the following regarding OS 6.1.5:
1. OLED on Pro Box remains lit
2. WOL does not work
3. Readynas Drop, Readynas Cloud, Readynas Replicate, Readynas Remote all work!
4. Temperature graphs work (after applying fix as suggested in this forum)
5. Status animations (ie. Fans, Aux, etc.) do not work.
6. Addons work flawlessly
7. Hard drive temperatures are 8-10 degrees (i.e OS6:32c 4.2.25: 40c)
All in all, OS6 is a huge improvement from 4.2.25. Frontview boots up faster, services work wonderfully.
I am presently running a Pro with 4gigs of Ram and a Q6600 cpu.
Thanks.
Message 99 of 172
Highlighted
Since 6.0.6 I don't have anymore the fan spinning like crazy so I didn't bothered to apply any fix, neither paid much attention to the temp that I suspected to be higher than reality.
My Ultra2 is now under 6.1.6, and today I finally did a Factory default to benefit from the NTRFS bug fix. After this factory default, I noticed that the temperatures where, now, correctly displayed (my NAS is on a balcony close to fridge temperature).
Well I was happy to see the system temp at 16°C, hdd temps at 21-22°C and CPU at 31°C. Then I restored the config file to gain the users accounts etc.. Here my problems is that the temp displayed came back to the faulty readings : all temps are increased by 5 to 10°C higher !
My question is : If I do an OS reinstall would it solve this temps reading problem ? I don't mind reconfiguring the NAS if I have to, but what I want to avoid is that after putting all my data back (2-3days..) then realizing that I need to do again a factory default !! (and then rebuild volume and put back everything again...).
your knowledge would be really helpful to save me a lot to time and hassle !!
thanks
note: i checked that I don't have any process burning the cpu/syst temp.
Ultra2 with ReadyNAS OS 6
Message 100 of 172
Top Contributors
Discussion stats
Announcements
