Brammeke
Apr 22, 2011Aspirant
Fan speed and system temperature via MRTG
Hi all
I'm trying to use MRTG to graph the fan speed and system temperature. This is an excerpt of my mrtg.conf:
The OID numbers are coming from http://www.oidview.com/mibs/4526/READYNAS-MIB.html. I'm not having any luck though, because MRTG is telling me this:
... and a similar message for the temperature.
What am I doing wrong?
Best regards
Bram
Target[fan]: .1.3.6.1.4.1.4526.18.4.1.2&.1.3.6.1.4.1.4526.18.4.1.2:public@127.0.0.1
Options[fan]: gauge, nopercent, noo
MaxBytes[fan]: 5000
Title[fan]: Fan
PageTop[fan]: <H1>Fan</H1>
YLegend[fan]: RPMS
ShortLegend[fan]: RPMS
LegendI[fan]: Rear fan
WithPeak[fan]: ymwd
Target[temperature]: .1.3.6.1.4.1.4526.18.5.1.2&.1.3.6.1.4.1.4526.18.5.1.2:public@127.0.0.1
Options[temperature]: gauge, nopercent, noo
MaxBytes[temperature]: 100
Title[temperature]: Temperature
PageTop[temperature]: <H1>Temperature</H1>
YLegend[temperature]: Celcius
ShortLegend[temperature]: C
LegendI[temperature]: System
WithPeak[temperature]: ymwd
SNMP Error:
Received SNMP response with error code
error status: noSuchName
index 2 (OID: 1.3.6.1.4.1.4526.18.4.1.2)
SNMPv1_Session (remote host: "127.0.0.1" [127.0.0.1].161)
community: "public"
request ID: 419153360
PDU bufsize: 8000 bytes
timeout: 2s
retries: 5
backoff: 1)
at /usr/share/perl5/SNMP_util.pm line 490
SNMPGET Problem for .1.3.6.1.4.1.4526.18.4.1.2 .1.3.6.1.4.1.4526.18.4.1.2 sysUptime sysName on public@127.0.0.1::::::v4only
at /usr/bin/mrtg line 1840
Best regards
Bram
- BrammekeAspirantGot this all working after a good night sleep. Will post complete procedure to get MRTG up and running later.
- vk2himAspirant
Brammeke wrote: Got this all working after a good night sleep. Will post complete procedure to get MRTG up and running later.
I'd be very interested in your procedure to get this going as I have had no luck ... thanks - BrammekeAspirantYes, I have.
I've created a little step-by-step: http://www.evernote.com/shard/s36/sh/250ea1a4-a0f9-4976-8d60-e72afc68c59a/28399ef87d3d250b2a8c17631e03887e
Send me a PM with your e-mail address if you want the relevant Perl modules and the config I created in your mailbox. - BrammekeAspirantThe configs... With these I can monitor about every aspect of the system, and even the influence of the sun on my garage. A similar configuration is possible on the ReadyNAS Duo. Don't know about other ReadyNAS devices.
mrtg.cfg# Created by
# /usr/bin/cfgmaker --global 'WorkDir: /c/mrtg' --output /etc/mrtg.cfg public@127.0.0.1
### Global Config Options
# for Debian
WorkDir: /var/www/mrtg
### Global Defaults
PageTop[$]: <a href="index.html">Back to main page...</a>
WriteExpires: Yes
EnableIPv6: no
WorkDir: /c/mrtg
Include: mrtg/mrtg.eth0.cfg
Include: mrtg/mrtg.cpu.cfg
Include: mrtg/mrtg.memory.cfg
Include: mrtg/mrtg.hdd.cfg
Include: mrtg/mrtg.fan.cfg
Include: mrtg/mrtg.systemtemperature.cfg
Include: mrtg/mrtg.hddtemperature.cfg
mrtg.cpu.cfgLoadMIBs: /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Target[localhost.cpu]: ssCpuRawUser.0&ssCpuRawUser.0:public@127.0.0.1 + ssCpuRawSystem.0&ssCpuRawSystem.0:public@127.0.0.1 + ssCpuRawNice.0&ssCpuRawNice.0:public@127.0.0.1
MaxBytes[localhost.cpu]: 100
Title[localhost.cpu]: CPU Load
PageTop[localhost.cpu]: <h1>CPU Load</h1>
Unscaled[localhost.cpu]: ymwd
ShortLegend[localhost.cpu]: %
YLegend[localhost.cpu]: CPU Utilization
LegendI[localhost.cpu]: Active
Options[localhost.cpu]: noo, growright, gauge
mrtg.eth0.cfg### Interface 2 >> Descr: 'eth0' | Name: 'eth0' | Ip: '10.0.0.72' | Eth: '00-0d-a2-02-77-3d' ###
Target[localhost.eth0]: 2:public@127.0.0.1:
SetEnv[localhost.eth0]: MRTG_INT_IP="10.0.0.72" MRTG_INT_DESCR="eth0"
MaxBytes[localhost.eth0]: 125000000
Title[localhost.eth0]: eth0 Traffic
PageTop[localhost.eth0]: <h1>eth0 Traffic</h1>
Options[localhost.eth0]: growright
mrtg.fan.cfg#LoadMIBs: /usr/share/snmp/mibs/READYNAS-MIB.txt
Target[localhost.fan]: .1.3.6.1.4.1.4526.18.4.1.2.1&.1.3.6.1.4.1.4526.18.4.1.2.1:public@127.0.0.1
Options[localhost.fan]: gauge, nopercent, noo, growright
MaxBytes[localhost.fan]: 4000
Title[localhost.fan]: Fan Speed
PageTop[localhost.fan]: <H1>Fan Speed</H1>
YLegend[localhost.fan]: RPMS
ShortLegend[localhost.fan]: RPMS
LegendI[localhost.fan]: Rear Fan
WithPeak[localhost.fan]: ymwd
Unscaled[localhost.fan]: ymwd
Colours[localhost.fan]: SKYBLUE#87CEEB,PLUM#DDA0DD,STEELBLUE#FFA500,PURPLE#800080
mrtg.hdd.cfgTarget[localhost.hdd]: .1.3.6.1.4.1.4526.18.7.1.6.1&.1.3.6.1.4.1.4526.18.7.1.6.1:public@127.0.0.1
MaxBytes[localhost.hdd]: 3000000000
Title[localhost.hdd]: HDD Free Space
PageTop[localhost.hdd]: <h1>HDD Free Space</h1>
ShortLegend[localhost.hdd]:
YLegend[localhost.hdd]: Free Space
LegendI[localhost.hdd]: Free Space
Options[localhost.hdd]: gauge, growright, nopercent, noo
kMG[localhost.hdd]: M,G,T,P,X
mrtg.hddtemperature.cfgTarget[localhost.hdd1temperature]: ((.1.3.6.1.4.1.4526.18.3.1.5.1&.1.3.6.1.4.1.4526.18.3.1.5.1:public@127.0.0.1 - 32) * 5) / 9
Options[localhost.hdd1temperature]: gauge, nopercent, noo, growright
MaxBytes[localhost.hdd1temperature]: 64
Title[localhost.hdd1temperature]: hdd1 Temperature
PageTop[localhost.hdd1temperature]: <H1>hdd1 Temperature</H1>
YLegend[localhost.hdd1temperature]: Degrees Celcius
ShortLegend[localhost.hdd1temperature]: °C
LegendI[localhost.hdd1temperature]: hdd1
WithPeak[localhost.hdd1temperature]: ymwd
Unscaled[localhost.hdd1temperature]: ymwd
Colours[localhost.hdd1temperature]: GOLD#FFD700,RED#FF0000,ORANGE#FFA500,DARK RED#8B0000
Target[localhost.hdd2temperature]: ((.1.3.6.1.4.1.4526.18.3.1.5.2&.1.3.6.1.4.1.4526.18.3.1.5.2:public@127.0.0.1 - 32) * 5) / 9
Options[localhost.hdd2temperature]: gauge, nopercent, noo, growright
MaxBytes[localhost.hdd2temperature]: 64
Title[localhost.hdd2temperature]: hdd2 Temperature
PageTop[localhost.hdd2temperature]: <H1>hdd2 Temperature</H1>
YLegend[localhost.hdd2temperature]: Degrees Celcius
ShortLegend[localhost.hdd2temperature]: °C
LegendI[localhost.hdd2temperature]: hdd2
WithPeak[localhost.hdd2temperature]: ymwd
Unscaled[localhost.hdd2temperature]: ymwd
Colours[localhost.hdd2temperature]: GOLD#FFD700,RED#FF0000,ORANGE#FFA500,DARK RED#8B0000
Target[localhost.hdd3temperature]: ((.1.3.6.1.4.1.4526.18.3.1.5.3&.1.3.6.1.4.1.4526.18.3.1.5.3:public@127.0.0.1 - 32) * 5) / 9
Options[localhost.hdd3temperature]: gauge, nopercent, noo, growright
MaxBytes[localhost.hdd3temperature]: 64
Title[localhost.hdd3temperature]: hdd3 Temperature
PageTop[localhost.hdd3temperature]: <H1>hdd3 Temperature</H1>
YLegend[localhost.hdd3temperature]: Degrees Celcius
ShortLegend[localhost.hdd3temperature]: °C
LegendI[localhost.hdd3temperature]: hdd3
WithPeak[localhost.hdd3temperature]: ymwd
Unscaled[localhost.hdd3temperature]: ymwd
Colours[localhost.hdd3temperature]: GOLD#FFD700,RED#FF0000,ORANGE#FFA500,DARK RED#8B0000
Target[localhost.hdd4temperature]: ((.1.3.6.1.4.1.4526.18.3.1.5.4&.1.3.6.1.4.1.4526.18.3.1.5.4:public@127.0.0.1 - 32) * 5) / 9
Options[localhost.hdd4temperature]: gauge, nopercent, noo, growright
MaxBytes[localhost.hdd4temperature]: 64
Title[localhost.hdd4temperature]: hdd4 Temperature
PageTop[localhost.hdd4temperature]: <H1>hdd4 Temperature</H1>
YLegend[localhost.hdd4temperature]: Degrees Celcius
ShortLegend[localhost.hdd4temperature]: °C
LegendI[localhost.hdd4temperature]: hdd4
WithPeak[localhost.hdd4temperature]: ymwd
Unscaled[localhost.hdd4temperature]: ymwd
Colours[localhost.hdd4temperature]: GOLD#FFD700,RED#FF0000,ORANGE#FFA500,DARK RED#8B0000
mrtg.memory.cfgTarget[localhost.memory]: .1.3.6.1.4.1.2021.4.6.0&.1.3.6.1.4.1.2021.4.4.0:public@127.0.0.1
MaxBytes[localhost.memory]: 1000000
Title[localhost.memory]: Available Memory
PageTop[localhost.memory]: <h1>Available Memory</h1>
ShortLegend[localhost.memory]:
YLegend[localhost.memory]: Physical + Swap
LegendI[localhost.memory]: Physical
LegendO[localhost.memory]: Swap
Options[localhost.memory]: gauge, growright, nopercent
kMG[localhost.memory]: k,M,G,T,P,X
mrtg.systemtemperature.cfgTarget[localhost.systemperature]: ((.1.3.6.1.4.1.4526.18.5.1.2.1&.1.3.6.1.4.1.4526.18.5.1.2.1:public@127.0.0.1 - 32) * 5) / 9
Options[localhost.systemperature]: gauge, nopercent, noo, growright
MaxBytes[localhost.systemperature]: 64
Title[localhost.systemperature]: System Temperature
PageTop[localhost.systemperature]: <H1>System Temperature</H1>
YLegend[localhost.systemperature]: Degrees Celcius
ShortLegend[localhost.systemperature]: °C
LegendI[localhost.systemperature]: System
WithPeak[localhost.systemperature]: ymwd
Unscaled[localhost.systemperature]: ymwd
Colours[localhost.systemperature]: CRIMSON#DC143C,MAROON#800000,GREY#808080,DARK SLATE GREY#2F4F4F
