Newman_
Nov 09, 2014Aspirant
Frontview is not loading after plugin install
After a trying to install Nas Monitor (I think that I maybe restarted NAS before installation was complete ) Frontview is not loadning anymore. Everytning else seems to work, like other installed plugins and accessing shares.
I´ve tried reinstalling OS by following a guide on readynas webbpage but it didn´t make any diffrent.
Can someone please tell med how to fix this?
- mdgm-ntgrNETGEAR Employee RetiredDo you have SSH access?
- Newman_AspirantYes I havs SSH access as admin. But I am not familiar with any commands there.
Skickas från min iPhone via Tapatalk - mdgm-ntgrNETGEAR Employee RetiredThe SSH user is root not admin.
# df -h
# df -i
# tail -n 20 /var/log/frontview/error.log
# cat /etc/frontview/addons/addons.conf
# ls -la /etc/frontview/apache/addons - Newman_AspirantOk, thanks I didn´t know that. But logged in as root and with the commands above I got following answers:
NewmanUltra2:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/md0 65536 16900 48636 26% /
tmpfs 126464 1 126463 1% /USB
/dev/c/c 30367744 128254 30239490 1% /c
NewmanUltra2:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 694M 3.2G 18% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 1.9T 1010G 837G 55% /c
NewmanUltra2:~# tail -n 20 /var/log/frontview/error.log
[Fri Aug 01 19:25:39 2014] [error] [client 127.0.0.1] File does not exist: /frontview/ui/resource/html/api
[Fri Aug 01 19:26:52 2014] [notice] Graceful restart requested, doing restart
apache-ssl: Could not reliably determine the server's fully qualified domain name, using 192.168.1.65 for ServerName
[Fri Aug 01 19:27:03 2014] [warn] RSA server certificate CommonName (CN) `192.168.1.91' does NOT match server name!?
[Fri Aug 01 19:27:03 2014] [notice] Apache/2.2.6 (Debian) mod_ssl/2.2.6 OpenSSL/0.9.8c DAV/2 mod_apreq2-20051231/2.6.0 mod_perl/2.0.2 Perl/v5.8.8 configured -- resuming normal operations
[Fri Aug 01 20:10:51 2014] [notice] caught SIGTERM, shutting down
[Fri Aug 01 20:17:56 2014] [warn] RSA server certificate CommonName (CN) `192.168.1.91' does NOT match server name!?
[Fri Aug 01 20:17:57 2014] [warn] RSA server certificate CommonName (CN) `192.168.1.91' does NOT match server name!?
[Fri Aug 01 20:17:57 2014] [notice] Apache/2.2.6 (Debian) mod_ssl/2.2.6 OpenSSL/0.9.8c DAV/2 mod_apreq2-20051231/2.6.0 mod_perl/2.0.2 Perl/v5.8.8 configured -- resuming normal operations
[Sat Nov 08 10:33:06 2014] [error] [client 192.168.1.99] File does not exist: /etc/frontview/addons/ui/READYNASREMOTE/language/sv, referer: https://192.168.1.65/admin/
[Sat Nov 08 10:33:06 2014] [error] [client 192.168.1.99] File does not exist: /etc/frontview/addons/ui/TWONKY/language/sv, referer: https://192.168.1.65/admin/
[Sat Nov 08 10:33:07 2014] [error] [client 192.168.1.99] File does not exist: /etc/frontview/addons/ui/BITTORRENT/language/sv, referer: https://192.168.1.65/admin/
[Sat Nov 08 10:33:08 2014] [error] [client 192.168.1.99] File does not exist: /etc/frontview/addons/ui/ISTATD/language/sv, referer: https://192.168.1.65/admin/
[Sat Nov 08 10:33:08 2014] [error] [client 192.168.1.99] File does not exist: /etc/frontview/addons/ui/TRANSMISSION/language/sv, referer: https://192.168.1.65/admin/
[Sat Nov 08 10:33:09 2014] [error] [client 192.168.1.99] File does not exist: /etc/frontview/addons/ui/PLEXMEDIASERVER/language/sv, referer: https://192.168.1.65/admin/
[Sat Nov 08 10:33:10 2014] [error] [client 192.168.1.99] DBI connect('rnp2user:localhost','rnp2config',...) failed: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111) at /etc/frontview/addons/ui/READYNAS_PHOTOS_II/RNP2_HANDLER.pl line 639, referer: https://192.168.1.65/admin/
[Sat Nov 08 10:33:10 2014] [error] [client 192.168.1.99] DBI connect('rnp2user:localhost','rnp2config',...) failed: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111) at /etc/frontview/addons/ui/READYNAS_PHOTOS_II/RNP2_HANDLER.pl line 736, referer: https://192.168.1.65/admin/
[Sat Nov 08 23:19:10 2014] [notice] Graceful restart requested, doing restart
Syntax error on line 3 of /etc/frontview/apache/addons/bzeetweb.conf:
Invalid command 'php_admin_value', perhaps misspelled or defined by a module not included in the server configuration
NewmanUltra2:~# cat /etc/frontview/addons/addons.conf
SLIMSERVER!!SqueezeCenter!!7.3.2.0!!/etc/init.d/squeezecenter start!!/etc/init.d/squeezecenter stop
READYNASREMOTE!!ReadyNAS Remote!!1.0.9.60!!/etc/frontview/addons/bin/READYNASREMOTE/start.sh!!/etc/frontview/addons/bin/READYNASREMOTE/stop.sh!!Other!!current_url==http://www.readynas.com/download/remote/READYNASREMOTE_CURRENT.xml::detail_url==http://www.readynas.com/remote
TWONKY!!Twonky!!5.1.5_Linn!!/etc/frontview/addons/bin/TWONKY/start.sh!!/etc/frontview/addons/bin/TWONKY/stop.sh!!Other
READYNAS_PHOTOS_II!!ReadyNAS_Photos_II!!1.0.2!!/etc/frontview/addons/bin/READYNAS_PHOTOS_II/start.sh!!/etc/frontview/addons/bin/READYNAS_PHOTOS_II/stop.sh!!Other!!current_url==http://www.readynas.com/download/addons/x86/current/READYNAS_PHOTOS_II_CURRENT.xml::detail_url==http://www.readynas.com/photos2
BITTORRENT!!BitTorrent!!1.3!!/etc/frontview/addons/bin/BITTORRENT/start.sh!!/etc/frontview/addons/bin/BITTORRENT/stop.sh!!Other
ISTATD!!Istatd!!1.6!!/etc/frontview/addons/bin/ISTATD/start.sh!!/etc/frontview/addons/bin/ISTATD/stop.sh!!Other
TRANSMISSION!!Transmission!!2.82.00!!/etc/frontview/addons/bin/TRANSMISSION/start.sh!!/etc/frontview/addons/bin/TRANSMISSION/stop.sh!!Other!!current_url==https://www.readynas.com/contributed/super-poussin/x86/TRANSMISSION_CURRENT.xml::detail_url==https://www.readynas.com/contributed/super-poussin/x86/TRANSMISSION_REL.html::icon_url==https://www.readynas.com/contributed/super-poussin/x86/TRANSMISSION_ICON.jpg
SQUEEZEBOX!!Logitech Media Server!!7.7.3!!/etc/frontview/addons/bin/SQUEEZEBOX/start.sh!!/etc/frontview/addons/bin/SQUEEZEBOX/stop.sh!!Other!!detail_url==http://www.logitech.com/speakers_audio/wireless_music_systems::icon_url==/addons/SQUEEZEBOX/icon.png
PLEXMEDIASERVER!!PlexMediaServer!!0.9.9.7.429-f80a8d6!!/etc/frontview/addons/bin/PLEXMEDIASERVER/start.sh!!/etc/frontview/addons/bin/PLEXMEDIASERVER/stop.sh!!Other!!current_url==http://www.plexapp.com/releases/PLEXMEDIASERVER_CURRENT.xml::detail_url==http://www.plexapp.com::icon_url==http://plexapp.com/releases/PLEXMEDIASERVER.png
BZEET!!Bzeet!!1.1!!/etc/frontview/addons/bin/BZEET/start.sh!!/etc/frontview/addons/bin/BZEET/stop.sh!!Other
DAAPD!!FireFly!!1.0.3!!start-stop-daemon -S -q -x /usr/sbin/mt-daapd!!start-stop-daemon -K -n mt-daapd
NewmanUltra2:~# ls -la /etc/frontview/apache/addons
total 52
drwxr-xr-x 2 admin admin 4096 2008-03-06 03:43 .
drwxr-xr-x 3 admin admin 4096 2014-11-09 13:26 ..
-rwxr-xr-x 1 admin admin 124 2008-05-24 04:13 BITTORRENT.conf
-rw-r--r-- 1 admin admin 109 2009-07-19 09:54 BZEET.conf
-rw-r--r-- 1 admin admin 191 2008-12-27 13:37 bzeetweb.conf
-rw-r--r-- 1 admin admin 112 2010-06-11 22:51 ISTATD.conf
-rw-rw-r-- 1 admin admin 139 2014-03-13 04:08 PLEXMEDIASERVER.conf
-rw-r--r-- 1 admin admin 70 2011-09-06 20:14 READYNAS_PHOTOS_II.conf
-rw-r--r-- 1 admin admin 715 2011-02-26 03:17 READYNASREMOTE.conf
-rw------- 1 admin admin 124 2013-08-12 12:10 SQUEEZEBOX.conf
-rw-r--r-- 1 admin admin 130 2013-08-12 18:25 TRANSMISSION.conf
-rw-r--r-- 1 admin admin 249 2010-07-05 17:54 transmissionweb.conf
-rw-r--r-- 1 admin admin 112 2010-06-03 15:19 TWONKY.conf - mdgm-ntgrNETGEAR Employee RetiredTry adding .old to the filename for those bzeet conf files then restart Frontview.
- Newman_AspirantOk, I need some help how to change filename. I did find som commands on the internet but it didi´t rally success all the way.
What does this message mean?NewmanUltra2:/etc/frontview/apache/addons# dir
BITTORRENT.conf PLEXMEDIASERVER.conf TRANSMISSION.conf
BZEET.conf READYNAS_PHOTOS_II.conf transmissionweb.conf
bzeetweb.conf READYNASREMOTE.conf TWONKY.conf
ISTATD.conf SQUEEZEBOX.conf
NewmanUltra2:/etc/frontview/apache/addons# rename BEZEET.conf BEZEET.old
Bareword "BEZEET" not allowed while "strict subs" in use at (eval 1) line 1.
Bareword "conf" not allowed while "strict subs" in use at (eval 1) line 1.
NewmanUltra2:/etc/frontview/apache/addons# - mdgm-ntgrNETGEAR Employee Retired
# mv BZEET.conf BZEET.old
# mv bzeetweb.conf bzeetweb.conf.old
# apache-ssl -f /etc/frontview/apache/httpd.conf -t && apache-ssl -f /etc/frontview/apache/httpd.conf -k restart - Newman_AspirantThank you very much, Frontview is loading again. I haven´t tested all functions yet but i guess everything else also works.
