Bob33Builder
Nov 02, 2020Aspirant
Problems trying to run ReadyNAS Duo V2 with Firefox and Windows 10
After trying unsuccessfully to run my old ReadyNAS Duo V2 and use it for sharing pictures, I shelved it again for future consideration. I posted a thread here about 10 - 11 months ago and got nowhere with my device.
Future arrived a few days ago. I have the need for multiple computer home backups, so thought I would get after this thing again.
I know it is an old piece of hardware and there are many newer models that likely work better, but I really do like this thing, it is paid for and it's mine. Sticker on the bottom says Product Number RND2000-200NAS. Model No says RND-2B. Front of unit, bottom right says ReadyNAS Duo v2.
I am running 2 - 2Tb drives in a RAID1
If I can only get it working properly.
Couldn't remember my password etc, managed to get into it via the RAIDar Browse button, saw there was nothing I needed, did a factory reset and started over. I set it all back up again. Thats when the problems really hit me.
I run the latest version of FireFox. I type my home network address - 192.168. etc and I am greeted with:
Secure Connection Failed
An error occurred during a connection to 192.168.0.25. PR_CONNECT_RESET_ERROR
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
I have spent nearly the whole weekend fiddling around with it, trying to get around this stupid error. I have come up blank and cannot figure out what this error actualy means.
I think it has to do with a certificate being invalid or no certificate or some fool thing like that.
I pick up my Samsung tablet, type in the address, and I am in. No problem. No errors, no blocking me at all.
I launch MS Edge, which I do not like and do not use, but it will let me in by clicking my life and title to my first born away - In other words, there is the option of proceed anyways and click 3 or 4 warning messages away. When the browser opens, it has a big Unsafe Site message at the top.
Most of the stuff inside the device menus is blank. I cannot do much with it. After several shutdowns and reboots of the device I have managed to get into it via MS Edge and my windows File Explorer. Dumping a buch of files on it now to play with it.
I know that with all the safety breaches, security challenges and all that going on that browsers and more have tightened up things so much that older hardware simply won't run, but surely there has to be a way to properly run this device....
Can anyone guide me on how to get around the browser errors?I cannot afford to fork out hundreds of dollars for a new NAS.
Thank you
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
The connection is being interrupted or terminated by your Firewall or security software. Have you tried accessing on another Computer?
What is the firmware version your Duo is running? If it's a Duo V2 it should have 5.x
- Bob33BuilderAspirant
Thank you,
I can access it from my Samsung tablet no problem. But I want to use my laptop, not my tablet. I didn't try another computer.
I can access it through MS Edge if I click away all the warnings about an unsafe site.
FireFox, my browser of choice, simply completely blocks me from accessing my own device, sitting on my desk 6 inches from my computer. So annoying!
The firmware is v5.3.13
When I had it open in Edge, I tried exporting the certificate that was created for Edge. Apparently a self signed certificate. I do not understand how these things are created and verified.
Using the export certificate function in Edge, I saved it in 2 different formats and tried to import them into FireFox. Neither one worked, FF wouldn't let me import them.
I forgot to mention, I run Kaspersky Total Security.
Thanks for your help.
- SandsharkSensei
PR_CONNECT_RESET_ERROR is not a certificate problem. It's telling you that somehting between the browser and NAS is blocking the connection, and the most likely candidate is your security software. Try disabling Kaspersky Total Security. If that fixes it and Kaspersky has separate settings for different programs, that's where you should look for a permanent solution.
Once you get past this issue, you'll still have to deal with the self-signed certificate.
