CharlesR
Dec 02, 2014Guide
RAID with JBOD
With 6.2 is there anyway to have a raid (two or more disks) and still have a separate addressable drive "outside" of the raid itself? I know it doesn't make sense but I might want to setup a dedicated drive for my WMC recordings via iSCSI. I have no interest in backing them up and the drive might get moved from one NAS to another (same OS release). Heck with the RN102's current pricing I guess I could simply throw one of them into action and be done with it...
- mdgm-ntgrNETGEAR Employee RetiredYou would disable X-RAID, destroy the default volume and create the volumes you want. You could create a volume that uses just the one disk.
- CharlesRGuideMy hope was to have both.. a raid and a standalone drive? My other data would reside on the multi drive raid. Let's say I have one disk now...
- I would disable X-Raid.
Insert new drive (2nd) - dedicated to iSCSI
Later insert a drive (3rd) matching the first drive
Then I could create a raid using drives one and three? - mdgm-ntgrNETGEAR Employee RetiredWell if some drive bays are empty, you could simply disable X-RAID, add a disk and create a new volume for the added disk. You can use a mixture of multiple drive and single drive volumes. Volumes don't have to all use the same RAID level.
- CharlesRGuideOK. Thanks. I'll do some reading now that I believe it's possible.
- CharlesRGuideOne last silly question... since I would have different volumes the type of drive wouldn't be important as along as any in a RAID were compatible with each other? I would go Red with the RAID(s) and who knows what with the standalone.
- mdgm-ntgrNETGEAR Employee RetiredIt is still important that you use a compatible drive with the standalone disk. I would still use at least a RED for the standalone disk. Green disks are not suitable.
- CharlesRGuideAfter some reading I'm left with one question which could be unsupported to a large degree. I guess it evolves around where and how the OS resides or doesn't...
Let's take for granted each device will have the same OS release. The first being a Legacy x86 device (say 6.2) and I bring it up with one drive. I turn off X-RAID2 and insert a new drive creating a second volume. The short question is... is this volume compatible with other devices running other chipsets? Such as say a RN102? Could it be inserted once the RN102 is up and running or is it dependent on firmware which supports the same processor architect?
Long story is I'm wondering if I can create a volume (outside of USB) which can be transferred to virtually any device as long as its on the same firmware level. I'm guessing no, but what the heck... - vandermerweMasterYou can do this between OS 6 devices, if you transfer the disks into a unit with different architecture you would need to do so with its power off, then do an OS reinstall using the boot menu.
I am not certain whether you could take a disk from legacy unit and put it into any of the current line of devices.
Obviously you can't do this with only part of an array. - CharlesRGuide
vandermerwe wrote: You can do this between OS 6 devices, if you transfer the disks into a unit with different architecture you would need to do so with its power off, then do an OS reinstall using the boot menu.
Thanks. I didn't know this was possible. Presuming the data (partition) is untouched?I am not certain whether you could take a disk from legacy unit and put it into any of the current line of devices.
That is the question... I thought you couldn't swap drives between chipsets without erasing them. - vandermerweMasterWell the current line of devices have several different architectures and the OS reinstall method works and preserves data and config.
What I don't know if there might be something different in the way disks from a legacy device behaved when moved even of they had OS 6 on them.
I must say that in general moving disks between units is not a good idea as a premeditated event. If it's being done in a crisis because of hardware failure then I think a backup is a simpler strategy. The data can then be restored to any device from backup.
PS
viewtopic.php?f=65&t=70642
