× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN 312 Firmware 6.6.1 Strange backup errors
sfpegasus
Tutor
Ever since the update, I keep receiving the following error:
Backup job Daily is already in progress. Consider adjusting backup schedule.
I have a daily backup job (external usb) that has alway run first thing in the morning when the ReadyNAS boots.  It's run fine for years.  I adjusted the time to two hours later with no better results.  Right now the admin page says the packup is in progress, but it's really not. I have to reboot and manually start the backup job.
Model: RN31222D|ReadyNAS 300 Series 2- Bay
Message 1 of 6
FramerV
NETGEAR Employee Retired
Re: RN 312 Firmware 6.6.1 Strange backup errors
Hi sfpegasus.
Do you have other back-up jobs?
Can you create a test back-up job. Just want to isolate if its affecting all the back-up process or just an isolated one.
Message 2 of 6
sfpegasus
Tutor
This is apparently bigger than a couple of backup errors.  Disabling the antivirus has returned my system back to normal.  The antivirus upgrade in 6.6.1 is buggy as all hell.  It's apparently the cause of my other post "ReadyNAS 312 ERROR System: Fan fan2 in enclosure Internal speed is below threshold".
Monitoring the antivirus definition file updates led me to find that my failures were happening right after these updates.
Message 3 of 6
FramerV
Hi sfpegasus,
I see, it could be related to the link below:
Lots of Virus detection after 6.6.1 Update
Message 4 of 6
sfpegasus
Tutor
Not really a solution.  We need a new OS update.  Not fond of beta testing on my network.
Message 5 of 6
FramerV
Hi sfpegasus,
I agree with you. Rest assured that this is being worked at. Hopefully the fix gets released soon.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2367 views
  • 0 kudos
  • 2 in conversation
Announcements
