- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN314 and RN212 connected over VPN instead of locally
- Mark as New
- Bookmark
- Subscribe
- Permalink
3 NAS units, all with IP address reservation on the home router. all 3 were connected locally over 192.168.1.210/1/2 until the RN314 developed a Block 25E error requiring OS reinstall over usb. Now the 314 and 212 units say "Connected (VPN)" while the RN528X still says "Connected (Local)". I can reach the admin pages of vpn units using readycloud but cannot reach them using their local IP address. Have run into this in the distant past but forgot root cause. How do I get these back on local network? Have already rebooted NAS drives.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN314 and RN212 connected over VPN instead of locally
An OS re-install would change a static IP, but you say you use address reservation in the router and DHCP in the NAS, so that's not it. Any chance you inadvertently switched which Ethernet port is connected? Address reservation is via MAC address, and each of the ports has it's own.
- Mark as New
- Bookmark
- Subscribe
- Permalink
double checked the MAC addresses were still correct for each NAS, also no ethernet cables have been touched.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What local IP address(es) is RAIDar showing?
Did you try rebooting the router and the two NAS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB wrote:What local IP address(es) is RAIDar showing? RAIDar and my router admin both show expected private IP addresses for bot NAS units - namely 192.168.1.211/212.
Did you try rebooting the router and the two NAS? Yes, more than once.
Surprised I can't find anyone in the forum with this issue, it's happened to me more than once over the years.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A DOS ping to .211 returns a strnge error message:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ping result in case pic didnt come through:
C:\Users\jkirk>ping 192.168.1.211
Pinging 192.168.1.211 with 32 bytes of data
Reply from 192.168.1.51: Destination host unreachable.
Ping statistics for 192.168.1.211:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reply from 192.168.1.51: Destination host unreachable.Ping statistics for 192.168.1.211:
Du you see the address when you run arp -a?
Are the NAS connected to the same switch (or router) as the PC?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes all on same network and switch. just checked on a second PC (also connected to same switch and on same network) and ReadyCloud shows the device as local - how weird is that? Both are Win10 machines, and both show the 528X as local. Sorry for brevity, carpal tunnel surgery on right hand last Friday so am typing with one hand.
- Mark as New
- Bookmark
- Subscribe
- Permalink
issue fixed by tearing down bonding on all 3 drives, disabling second ETH port on all 3 drives, turning off LAG on XS716E switch, and rebooting everything including PC's.
