hysten
Oct 23, 2017Aspirant
ReadyNAS 2100 will not boot
Hi.
Our ReadyNas 2100 is not accessible on the network after bootup. We followed the process to reinstall the OS as per the instructions in the following link https://kb.netgear.com/24872/How-do-I-access-the-boot-menu-on-my-ReadyNAS-1500-2100 , however the Boot menu is not accessible to allows us the selection of the OS re-install. Please help.
Thanks and regards
Anthony.
Does it respond to ping?
Did you try using RAIDar to check the status? https://kb.netgear.com/20684/ReadyNAS-Downloads
- hystenAspirantHi. No it does jot respond to ping, albeit the NIC cards both light and blink. RAIDar does not find it in the network.
Thanks.- StephenBGuru - Experienced User
Ok. Try powering down, then remove the disks (labeling by slot). Then power up again, and see if RAIDar finds it. It should discover it, and report a "no disks" status. Replace the disks with the NAS powered down.
This will tell you if the issue is with the disks or the chassis.
