User123456789
May 16, 2018Follower
ReadyNAS Pro full/no ssh login
It is never good when your model number doesn't even show up in the list (RDNP6310-100NAS).
Anyway, I am trying to recover data from my device. The firmware version is 4.2.31. The device screen says c: 0/9156GB free. I have data in one share ("backup"). Accessing that share through https shows no files. My workplace would not let me put the device under the domain controller because it is not secure enough anymore (too old), so no CIFS unless I set up a separate temporary networkd. I enabled ssh, but I can't connect as root using my admin password (it says "Permission denied"). I logged via telent while in tech support mode and the password in the /mnt/etc/shadow file looks to be the same as my admin password. I'm not sure how to mount the full data drives using that type of access. I've emptied all of the logs I can via RAIDar. Any suggestions?
Thanks!
1 Reply
I've sent you a PM with a couple things you can try.
One thing you should look for is a full OS partition.
