Orbi WiFi 7 RBE973
Reply
Readynas Pro 6 won't boot
tb303
Guide
Hi,
Since years I am a happy ReadyNas Pro 6 owner.
Half a year ago I upgraded the ReadyNas Pro 6 to Readynas OS6. It worked just fine and fast!
A month ago I stared to have some disk problems on disk 1 which I negledted a little.
A few days ago I switched the readynas off to take ot to the office and have a look at the disk that was repporting errors and when I took the readynas to my office and powered it on again, it wouldn't boot and It also wouldn't boot into boot menu.
What have I already done?
1. I have checked the PSU. It working 100%
2. I have checked memory. 100%
3. I have connected a VGA adapter. The hardware seems to be working fine.
4. I have tried to get it into boot menu. Fails.
I suspect the bootflash has been wiped.
I have tried serveral readynas USB recovery disks but these won't boot either.
If I boot from a Windows 10 USB stick, installation of Windows seems to be no problem.
Can anybody give me detailed instructions how to debug and how to get the bootloader written to flash again?
I have some linux experience.
KInd regards,
Michel
Message 1 of 10
Accepted Solutions
tb303
Guide
Re: Readynas Pro 6 won't boot
Thanks to the great help of mdgm my Readynas Pro 6 is running the lastest Readynas OS6 again!
I ended up using dd on a debian life boot disk to dd flash the image mdgm supplied to me back to the internal flash.
After that I mounted the partition and copied the supplied serial number file to the internal flash.
Mdgm, thanks for you great support!
Kind regards,
Michel
Message 9 of 10
All Replies
tb303
Guide
A few screenshots of the bios:
Message 2 of 10
mdgm-ntgr
NETGEAR Employee Retired
If USB Boot Recovery works the system should automatically power off when done.
You still can't get into the boot menu after doing USB Boot Recovery?
Message 3 of 10
tb303
Guide
I have tried all available USB recovery images. They won't work on my machine.
What I see on the console is:
And then simply nothing happens 😞
I have booted from a Debian live USB and noticed that the MBR on the internal 128MB USB memory is corrupt.
What I need is a RAW image of the internal 128MB USB so I can restore it inclusing the MBR.
Is someone willing and able to make a dd image of the internal flash?
All you need to safely do that is ssh root access to your Readynas Pro 6.
If you ssh into your readynas, first figure out the path to one of your shares.
Let's say you cd to your share at:
/data/myshare
Then enter the following command:
fdisk -l | grep 128
This will show you a 128MB USB device. Most probably /dev/sda
Then enter:
dd if=/dev/sda of=/data/myshare/usb.img bs=512k conv=noerror,sync
This will make a RAW image of your internal flash and store it on your share.
If you could zip that and send this to me somehow, I would be eternally thankfull!
Cheers,
Michel
Message 4 of 10
Sandshark
Sensei
But wouldn't that also include the serial number, efffectively cloning my Pro to yours for ReadyCloud and such?
Message 5 of 10
tb303
Guide
I'm not 100% sure, but it would be quit silly if Netgear would have stored it on flash.
I presume it is stored in the hardware (bios or eeprom or something like that).
Message 6 of 10
Guru
Maybe best to wait for mdgm or another Netgear person on this.
Message 7 of 10
mdgm-ntgr
We store the serial number and other EEPROM data on the internal flash on legacy x86 and ARM ReadyNAS. I have replied to your PM.
Also USB Boot Recovery formats the USB key. If I recall correctly it puts a new MBR on it, so it's a bit surprising it didn't work.
Message 8 of 10
tb303
Guide
Kind regards,
Michel
Message 9 of 10
mdgm-ntgr
Great!
Glad that fixed it.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 5182 views
  • 6 kudos
  • 4 in conversation
Announcements
