mike_coreit's avatar
mike_coreit
Slow to open folders
Hi I have an issue that has started recently after updating the NAS firmware to 6.9.4 and re-inviting the ReadyCLOUD users.
When the users in the office try to open certain shared folders it may take up to 4 minutes to list the contents. It didn't used to take this long and the folders are not particularly large (there are only 20 sub-folders).
In troubleshooting I have rebooted the NAS and this seems to resolve the issue for a day, but then the issue will return. I have also found that if I turn off ReadyCLOUD then this also stops the issue from occurring - however the users need to use ReadyCLOUD to work remotely.
Is there any way to resolve this?
The users access the shared files with Windows machines/SMB
  • Maybe there is a fix coming in the firmware, but you really didn't do your homework well in choosing a NAS.  The 102 is not really suited for multiple users connecting on a regular basis, especially remotely.  Besides having the least powerful processor of the bunch, it has half the RAM (and it's not upgradable).  It's really intended for home use.
    A 212 would be minimal, I'd think, and something more powerful like the 422 (or even a 424 for expansion capability) would be best.  At the time you bought the 102, the 202, 312, and 314 were probably your other choices.
    • StephenB's avatar
      Are users also using ReadyCloud in the office?  If so, try directly accessing the NAS with SMB and see if that helps.  It's possible that ReadyCloud is routing the info through the ReadyCloud internet servers (which would certainly degrade performance).
      I agree that your NAS is almost certainly underpowered.  I suggest considering upgrading it - perhaps using the existing RN102 as a backup.  In the meantime, if the Antivirus service is enabled on the NAS, you should turn it off.
      Another approach is to deploy a VPN router (or perhaps ZeroTier), and drop ReadyCloud.
      • mike_coreit's avatar
        mike_coreit
        Sandshark The performance of the NAS drive has been fine over the last few years - are you suggesting the firmware update had caused the device to become obsolete?
        Retired_MemberI have followed the steps in the performance articles. In an unrelated matter is there any reason why the guide mentions to not encrypt a volume? I don't use encryption at the moment but I may need to the future.
        StephenB I have also tried logging out of the ReadyCLOUD app but the issue continues. We do not use the anti-virus on the NAS.
        I have checked the resource usage of the NAS and this looks fine only 20% of the CPU and 62% memory.
        I may consider replacing ReadyCLOUD with a VPN router but this would be a last resort.
ProSupport for Business
