ChunkySocks's avatar
Aug 26, 2014
Stuttering video playback - help with troubleshooting
I have a ReadyNAS Ultra 2 running RAIDiator 4.2.26 - the video playback from the ReadyNAS is fine for about the first 30 seconds or so then both the video and the audio starts stuttering. Sometimes the playback will right itself but not for long and it eventually starts stuttering again.
So far I have tried:
  • rebooting the ReadNAS
  • switching off add-ons (e.g. Logitech Media Server, Transmission) in case they were using too many resources
  • checking I had the latest ReadyDLNA service installed - I had 1.1, downloaded and installed 1.1.2.3, unfortunately didn't solve the issue
  • re-scanning media files, both before and after updating ReadyDLNA (not really relevant, I know, other than the ReadyNAS wasn't seeing some video files which it now does)
Please note however, I was able to stream the same video files without any issues from the ReadyNAS to my laptop (via an ethernet connection).
The chain when attempting playback from the ReadyNAS is:
ReadyNAS > router > Panasonic BluRay/DVD player > TV
with ethernet cables connecting the ReadyNAS and the BluRay/DVD player to the router then there's an HDMI cable from the BluRay/DVD player to the TV.
The files are 1080p HD files, smaller files at less resolution don't seem to cause the same issue.
Is there anything else that should be attempted?
Thanks in advance for any replies.
  • Is your TV buffering after that 30 seconds or does it just play part of the file and then stop? Does the ReadyNAS seem really busy? What kind of network are you using, 10/100 or Gigabit networking? Is TV also gigabit or 10/100?
  • How did you stream to your laptop?
    Did you use dlna?
    Did you go through your router?
    What model of Panasonic player are you using? Is it's firmware up to date?
    The bottleneck is likely to be the Panasonic, not the readynas.
  • Thanks for the swift replies.
    It seems to play a few frames, stop, then start and play a few frames, then stop etc.
    Not that I can discern, it doesn't sound like it's overexerting itself and when I was attempting to troubleshoot it from my laptop, FrontView seemed to respond fine although I can't remember if I was using FrontView whilst playback was being attempted.
    Not sure, how do I find that out? The router is a Virgin Media Superhub (made by Netgear I believe). Are all ethernet cables equal or is it worth checking them? I think but can't be sure that they are all Cat5 cables, can check but if it's a network setting or dependent upon the router then... dunno, not sure what I'm talking about tbh.
    Don't know - it's a Panasonic Viera TX-L37U3B
    ReadyNAS > router > laptop (all connected via ethernet cable)
    Did you use dlna?
    Good point, no, opened and played the file on my laptop using VLC.
    Yes.
    BluRay Disc Player DMP-BD75
    Don't know, will have to check and look although it's possible, I vaguely recall doing something whilst messing about with the settings ages ago when I connected it up to the router. If updating the firmware is more involved than simply selecting an option after it's connected up to the router via ethernet then no.
    OK, if it is, that could be the least worst option to fix.
    Thanks again for both your posts.
  • You are trying to stream MKV files? That Panasonic only seems to support those video files as far as I can see.
    You may be better off getting yourself a dedicated network media player like a Dune Hd or Mede8er.
  • Yep, all MKV.
    Haven't got the budget for Dune HD or Mede8er atm but any form of shiny gadget is always appreciated but it also won't fly with the other half :(
  • StephenB's avatar
    I'm not completely sure I get the playback chain.
    You are going ReadyNAS -> Laptop (VLC) -> BluRay Disk Player -> TV?
    If so, is the laptop wireless?
    ReadyDLNA would not be used at all if you are doing the above.
  • Apologies if I didn't make it clear enough - when attempting playback on the TV the playback chain is:
    When attempting playback on my laptop the playback chain is:
    So if I use VLC on my laptop to playback a video file from the ReadyNAS, am I right in thinking that using ReadyDLNA will not be involved?
    If so, then that makes it unlikely to be streaming/data issues from the ReadyNAS or issues with throughput via the router and makes it more likely to be an issue, as others have already suggested with the BluRay/DVD player or TV.
  • StephenB's avatar
    The fact that you can play these videos on the laptop means that NAS and the network have enough throughput to deliver the content. It would be useful to get a rough idea of the needed throughput though. A typical MKV 1080p movie runs about 8 to 12 GB. Is that approximately what you have? Or are you streaming full bluray quality (typically 25-50 GB)?
    The run of the mill 1080p MKV is about 12 mbit/s, the full BluRay version runs about 40-50 mbit/s
    Basically yes. There are several possibilities
    (a) ReadyDLNA might have trouble processing the MKVs for some reason - header compression for instance will sometimes get in the way.
    (b)The BluRay player uses dedicated hardware to decode the H.264 video in the MKV, and is specifically designed for the H.264 profile used in BluRay disks (and in some cases also the profile used by AVCHD). It is possible that your MKVs aren't compliant with those specifications.
    Posting a mediainfo analysis of one of the videos would help sort that out. http://www.videohelp.com/tools/mediainfo is one download source - you will want to opt out of the adware installs. If you right-click on the MKV, you should be able to launch mediainfo. Select the text view, and cut/paste the analysis into a followup post, and I can take a look at it. (You can PM me with the analysis if you prefer).
    Another approach is to find a short video (perhaps a downloaded 1080p movie promo), and attempt to play it on the BluRay player from a flash drive.
    (c) There might be other incompatibilities between the ReadyDLNA server and the Panasonic DLNA client.
  • Aye - 8-12GB files.
    Will check the firmware of the BluRay player to see if it's been updated or needs updating and also look into (b) a bit further - tomorrow hopefully when I have more time.
    Thanks for the suggestions.
ProSupport for Business
