JustKJ
Sep 23, 2016Aspirant
Time Machine slow after 6.5.2 update
It may be a coincidence, but I just updated my ReadyNAS to firmware 6.5.2. I back up three Macs to the TimeMachine i have on the unit. The time machines have worked fine since when I purchased it, very quick (other than the initial) or if I have turned off TM on the mac for other reasons, it may take a little longer to back up. Currently one one MAC is on and being backed up, the other are laptops and are not in use.
Yesterday, I noticed that timemachine was backing up a LARGE change--a downloaded back up a website that I had moved off to a seperate storage area. The compressed file was 1.2GB. When I checked in on the Progress of the back up, it seemed hung at 980MB of 2.5GB and estimated 6 hours to complete. That is FAR ouside the range of normal time range
I stopped the back up, deleted the large file and let TIme machine restart to run overnight. This monring it is sitting at 538.7MB of 1.38GB, an estimate of 10 hours... and it takes 45 seconds per each 0.1MB to tick off.
Anyone else having issues? Is there something I am missing?
- gbeddowLuminary
What version of the Mac OS are you using?
The reason I ask is I've seen something similar: I, too, upgraded to ReadyNAS 6.5.2 and, when I went to do a Time Machine backup from my MacBook Pro running the latest macOS Sierra 10.12, it took FAR longer than normal to "complete".
But even worse, not only did it NOT actually complete the backup, ALL backups for that MacBook Pro were lost: Even though Time Machine said the most recent backup was the newly completed one, trying to enter Time Machine displayed "Can't connect to a current Time Machine backup". The only option at that point was, from ReadyNAS, to delete and recreate the Time Machine backup share, then start a new backup, losing all backup history. The latter backup is still underway as I write this, but seems to be making reasonable progress; hopefully it'll be solid when it's done.
HOWEVER, on 2 other Macintosh laptops on this same network, both running the previous OS X El Capitan, new, incremental Time Machine backups continue to work just fine to the same ReadyNAS 6.5.2.
Granted, my sample size is small but, in my case at least, it looks like Apple made changes to AFP or other elements of Time Machine backups in macOS Sierra that, in combination with the way ReadyNAS works, require you to start over, losing your backup history. :(
- mdgm-ntgrNETGEAR Employee Retired
Which services are you running under System > Settings > Services?
Which apps do you have installed?Which ReadyNAS model is this with?
I think it's a good idea to do a fresh full backup after the annual major OSX update anyway and that's what I normally do.- JustKJAspirant
SMB, AFP, NFS, ReadyDLNA, Rsync, UPnp HTTP HTTPS, Antivirus
Which apps do you have installed?Anti-VIrus Plux
ReadyNAS 314
I think it's a good idea to do a fresh full backup after the annual major OSX update anyway and that's what I normally do.I have not updated past El Capitan latest version 10.11.6
- JustKJAspirant
I have not upgraded yet. El Capitan 10.11.6
It took the iMac 16 hours to complete a backup of 6 GB. when the next interval come, there was 650MB to back up and I cancled it after 2 hours as I needed to shut the it down to install a new UPS.
- FrancysenAspiranthello, order to use hd connects to my router to use time machine, which kind of format type do you use? NTFS? thansj
Francysen wrote:
hello, order to use hd connects to my router to use time machine, which kind of format type do you use? NTFS? thansjThis is in the wrong forum - it should be in the WiFi Router forum. Please repost it there, and include your Netgear router model.
Here's a link: https://community.netgear.com/t5/WiFi-Routers/ct-p/home-wifi-routers
