× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Unable to join ADS when netbios name has underscore
aschild
Hello,
we have a new ReadyNas 3138 with Firmware 6.9.2
Setup was smooth and now we try to integrate the users with our existing AD.
The problem we are facing is, that the nebios name is always is marked red and the "Apply" isn't doing anything.
Our netbios domain name includes a underscore, which IS allowed in MS networks.
The FQDN is very different, but does not seem to be the trouble.
NetBIOS Domain Name: XXXX_DO
FQDN: mail-i.xxxx.xx
As soon as I remove the _ from the NetBIOS Domain Name the field/label is no longer red and when I click "Apply" it tries to apply, but of course then fails.
Any ideas how I can join our ADS with such a naming?
BTW: We know that neither the NetBIOS nor the ADS FQDN match the current best practices, but this is a very very old domain, dating back from NT 3.1 days
Model: ReadyNAS-3100|ReadyNAS-3100
Message 1 of 8
Accepted Solutions
Marc_V
NETGEAR Employee Retired
Re: Unable to join ADS when netbios name has underscore
Hi @aschild
Can you try putting AUTO in the NetBIOS field just to test.
Message 7 of 8
All Replies
Guru
Netgear used to allow _ in their hostnames, but a couple of releases ago they changed their software to be compliant with IETF RFC 1123 (published 1989), which does not allow that character.
As far as I know there is no workaround.
Message 2 of 8
aschild
But it's in the Netbios Domain name, not in the host names.
And the RFC isn't relevant for Microsoft products anyway, they had their own "standards" in the past.
The fqdn is valid and rfc 1123 compliant.
Message 3 of 8
Guru
I hear you.  Note I don't work for Netgear either.
But at the moment I think your only option is to change your netbios name to remove the underscore.  I don't know of any workaround.
Message 4 of 8
aschild
Thanks (and no offence meant by my previous reply)
Message 5 of 8
Guru
None taken Smiley Happy
Message 6 of 8
Marc_V
Hi @aschild
Message 7 of 8
aschild
It did work with AUTO as the Netbios name.
After "apply" it fills in the correct Netbios name, including the underline.
So later on we can't save it anymore, but chaning it back to AUTO works once more.
It works for me this way, thanks
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2654 views
  • 2 kudos
  • 3 in conversation
Announcements
