claynz
Jan 12, 2021Guide
Volume root is degraded
I would like to completely reconfigue my NAS unit after a Volume root is degraded message showing up after running diagnostics.
I'm only running 2 drives in this unit as JBOD no need for RAID as I have the same amount of drives on the PC.
I have already taken the drives out and tested them for errors but are OK.
What is the best way to do this? so I can simply add another drive at a later stage.
I would like one drive storing TV Shows and the other drive Movies, Video's, Documents etc.
Just to clarify this, the OS partition is always mirrored on all drives - so it is RAID-1, no matter what RAID mode you are using for your data volume. That ensures that the NAS can boot from any disk.
I'd do a factory reset with one drive installed. Switch to FlexRAID as soon as the NAS is set up.
Then hot-insert the second drive, select that disk on the volume tab, and create a second jbod volume.
I suggest either erasing the second disk, or unformatting at in a PC before you insert it. If you don't do that, the NAS will require you to format the drive the NAS before it lets you create the second volume.
- claynzGuide
What is the best way to do a factory reset?
There's no "best" way, but there are three options:
- use the web ui: system->settings->update has a "Perform Factory Default" control.
- use the boot menu: see pages 74-75 here: https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
- Remove the disks, and either erase them or un-partition them in a PC. Reinstall disk(s) with the NAS powered down. On power up, the NAS will do a factory install.
