× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
read readynas volume using usb port windows 10
swope1221
HI everyone, my readynas 102 is having some issues, and I want to reset it to factory defaults.  I have tried to back up the data to an external usb 3.0 drive, but the backup crashes and never finishes.  I have tried using sync software, but nothing works.  The data is intact on the two 3 tb volumes i have installed in a raid 1 config, but since i can't back it up or sync it if I factory reset all my data is lost.  I have a usb enclosure for the hard drives I have installed in the readynas, but I know I can't simply plug it in a usb port and read it on my pc.  What can I do to extract the data?  I am on firmware 6.4.0 if that matters.
Thanks for your help.
Eric
Message 1 of 8
Guru
Re: read readynas volume using usb port windows 10
Have you tried connecting the USB drive to the PC, and using drag/drop to copy the data?  Or use teracopy (which can verify).
Message 2 of 8
swope1221
Hi Stephen, I have, but I believe the drives are formatted inside the readynas such that they are not readable by just plugging into a usb port on a pc.  I believe the are formatted btrfs, which windows can't natively read.  I didn't know if there was a program I could download to windows so I can plug in and read the data from the network drives, in the same way I plug in a thumb drive and it reads it.
Message 3 of 8
Guru
The external drive wouldn't be formatted as btrfs.  It might be ext, but you could reformat it as NTFS and drag/drop the data from the NAS to the external USB drive.  It's possible this might crash (as the backup does), but it is worth a try.
It is possible to read the RN102 internal drives, but you'd need to be running linux.  I believe an arch LiveUSB drive supports btrfs - though I haven't tried it myself.
Message 4 of 8
swope1221
Thanks Steven, I forgot to mention I did try the drag and drop too, but the Readynas hangs with this too.  I was hoping to attach one of the internal drives to a pc using the usb enclosure and read the info directly from it, but as you mentioned I'm not sure what to use.  I saw some program from diskinternals posted when I googled it, but I'm not sure it will work. http://www.diskinternals.com/linux-reader/features.shtml
Message 5 of 8
Guru
 Linux Reader won't work with the RN102.
Message 6 of 8
swope1221
Yeah, I just tried it. Smiley Mad Do you know of anything that will let me read the drives if I connect them to a usb port on the pc?
Message 7 of 8
Guru
No.  You'll need to be running linux.  As I said above, I think the arch usbLive setup will work.  Since you'd be booting off a USB, your windows OS will remain intact.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3234 views
  • 0 kudos
  • 2 in conversation
Announcements
