Laserbait
Aug 16, 2016Luminary
Balancing takes weeks to complete
My RN204 running 6.05.01 with 3x 4TB and 1 2TB disk was running at about 80+% full between data and snapshots (even though I was only using about 4 TB for my data). I tried to do a balance, and after 3-4 days, it only got to about 6%, and the performance was abysmal.
I cleared out all my snapshots and and moved data around so that I was only about 25% full, and the balance took just minutes. Now I have a schedule to balance every other day.
It seems to me that balancing is pretty critical to BTRFS and it's capacity reporting and performance. Why is it not just run every day by default? I would expect that it would be pretty fast if it was run often.
- mdgm-ntgrNETGEAR Employee Retired
Running it every day is way more than enough and unnecessary. Once a week at most should be sufficient.
If you never run a balance the filesystem may become quite unbalanced and the first subsequence balance may take a long time especially if the volume is quite full and the space is nearly fully allocated- StephenBGuru - Experienced User
Agreed. I run it once a quarter, and it completes pretty quickly (the last one completed in 30 minutes). Perhaps start with once a week, and then try once a month and see if the completion time stays low.
- LaserbaitLuminary
I was doing the balance every month, but I have a lot of change data going to the RN204 (daily backups from my computers using Veeam with a 5 day retention), so in my case, I think the balance needs to be done more.
