MikeyOT
Jan 30, 2017Follower
Can not upload from browser after upgrade to 6.6.1
After upgrading to 6.6.1 I have problems with uploading files. When I have browsed to the file I want to upload and then clicked on "Upload", nothing seems to happen. Then the screen goes blank and after that I cannot see Shares. I close the browser page, re-open it and find the upload has been successful. This happens EVERY time I upload a file and I get the same result with dragging and dropping a files into the ReadyNaAS window. This has happened only since the upgrade to 6.6.1.
Any ideas?
- Retired_Member
Option1) Might be caused by the browser. If not already done might want to try MSEdge, Chrome, Vivaldi and last but not least good old Mozilla Firefox.
Option2) Might be caused by a high-resolution screen (eg 1920x1080 or higher) and the related graphics processor. Might want to try with trusty old laptop and lower resolution.
Option3) Disable AV service and try again
Option4) Wait for update to firmware 6.7
It might be helpful to use RAIDar to check the status.
