markg1's avatar
markg1
NV+ wont power up
I have NV+ that is about 6.5 years old, and has been running pretty much continuously since purchase.
We recently went on a 2 week vacation, so I turned everything off including the NV+. Now it wont power back up.
when I hit the power button NOTHING happens; no light, no fan, no noise, nothing.
sounds like power supply, but I don't really know. I tried it on multiple power outlets just to make sure it wasn't that.
does anyone have any troubleshooting tips for this box?
thanks
mark
  • Mark,
    There is a lot of discussion of this topic at this link
    http://www.readynas.com/forum/viewtopic.php?f=24&t=65944
    In the short term, you want to get a friends NV+, and insert disks in.
    There is another link on the Forum, from 2009, I think re wiring in a alternative power supply.
    Interesting that you have got 6.5 years of usage. You are out of 3 or 5 year warranty.
    The power supplies will go in these NV+ v1's eventually, so it is important to have files backed up, and photo
    burnt to CD's for example.
    Regards, Marto
  • thanks for the info
    fyi, this is the server I use for backup, so no lost files (unless the main server decides to die in the meantime...)
  • StephenB's avatar
    Check this post: viewtopic.php?t=10259
    If the NAS serial number is within the specified range, then you are entitled to a new power supply from netgear, even if you are out of warranty.
    outside that range, unfortunately, but thanks for the tip!
  • I found this power supply that looks like it should fit:
    250W Enhance ENP-7025B Power Supply 80 PLUS Bronze Certified
    anyone know if it will for sure? or any other suggestions?
    it is $45 on amazon vs $129 for a NV+ specific one
    thanks
    mark
  • I went to order the enhance supply, but someone in the feedback section said that Netgear would sell me a power supply for about $26 shipped.
    so I called netgear support and they sold me one.
    saved me a ton of aggravation modifying the wiring
    ps. this post just goes to show that netgear participation on this forum is DEAD
ProSupport for Business
