dman66's avatar
dman66
Tutor
Jun 27, 2012
ReadyNAS Pro Data Recovery? (#18789299)
I was attempting to upgrade the firmware in my ReadyNAS Pro from 4.2.13 to 4.2.21 and it bricked itself (see the case referenced).
Is there any way to recover the data outside of the ReadyNAS?
I put the 5 drives in my Linux box and it sees them all with their partitions, etc.
Doug
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Yes it is possible to recover data outside of the ReadyNAS, however it would be recommended to try other options first.
    How bricked is the unit? Does the boot menu work?: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
    If you haven't already can you try the suggestion here to use a spare disk (must not be from your array) to update the unit to 4.2.17 etc.: http://www.readynas.com/forum/viewtopic.php?p=340135#p340135
    Welcome to the forum!
  • It is fully bricked :)
    It doesn't even get past 'ReadyNAS' on the display. The boot menu doesn't work... nothing.
    Doug
    mdgm-ntgr
    When did you purchase the ReadyNAS and what model Pro is it? Is it still under warranty?
    If you get a RMA, put a spare disk in the RMA unit and ensure the firmware installed is 4.2.17 etc.
  • I bought it in 2010 from Amazon so it should still be under warranty. Unfortunately it seemed it was bought previously in 2009 (Netgear even had support cases logged against it) and returned as defective and then sold to me :(
    The current warranty is good for another 2 years - but Netgear won't honor it for me until the registration is transferred and I'm getting the run around trying to get it transferred. Amazon stepped up big time and is willing to let me return it - but I want to try and get the data off first.
    It is a "NETGEAR ReadyNAS Pro Pioneer Edition 6-Bay (Diskless) Network Attached Storage RNDP600E".
    It had 5 drives on it with one empty drive bay.
    Doug
    mdgm-ntgr
    Well if Amazon would let you return it you could buy an Ultra 6 Plus (3 year warranty) or Pro 6 (5 year warranty) and try the suggestion I gave above.
    As for recovering the data using a Linux machine (if you really want to do that) you'd need to start the RAID, scan for the volume and mount it.
    I think the commands you'd need are something like this:
    sudo su
    apt-get install lvm2
    mdadm --assemble --scan
    vgscan
    vgchange -ay c
    mount /dev/c/c /mnt
    Edit: oops meant to say Amazon.
  • Thanks a milion for the commands - I had forgot the 'mdadm' step.
    I've got it mounted and all the data appears intact - time to start copying!
    Doug
ProSupport for Business
