- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
A7000 Not Connecting to Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have rebooted the computer (running Windows 10), reinstalled the gateway, but to no avail. I had to revert to the original gateway to be able to work today, and would greatly appreciate any assistance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A7000 Not Connecting to Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Isisunit wrote:
It does not get an assigned IP address, nor can I ping from that computer. Also, if I try connecting the PC all my other devices get kicked off the network.
Could it be a Windows thing? Have you running the Network Troubleshooter?
By changing your network infrastructure, you have changed the network as far as Windows is concerned.
In your shoes, as this is an important work machine I would investigate the use of Powerline Ethernet instead of wifi. That turns the mains circuit into an Eternet network. If the mains circuit is up to it, Powerline is easier to set up and less prone to interference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Isisunit wrote:
Thank you for the suggestion. The only change was the Xfinity gateway modem. My Windows 10 works just fine on the older modem (XB6-A)...
You have changed your network. Windows expects to see the old one. I repeat. Check Windows.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Isisunit
We’d greatly appreciate hearing your feedback letting us know if the information @michaelkenward provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having the exact same issue. I have been all over windows. I am not sure what exactly to check. I have tried to forget the connection. I uninstalled and reinstalled the driver. I did try the network trouble shooter. Those did not work. Is there something else that should be checked or changed in Windows?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possibly, possibly not.
Without a detailed description of what is happening at your end, what you have tried and what happened, it is impossible to tell you where to look for solutions to whatever problems you may have.
It is usually best to start your own conversation.The paid admins will have moved on to new conversations, especially when the person who started this one has disappeared without answering important questions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
