- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
WNCE2001 power led blinking green and no connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNCE2001 power led blinking green and no connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
tftp -i 192.168.1.251 PUT C:\WNCE2001-V1.0.0.26NA.img
Also, before hitting enter, I plugged the Ethernet cable into the WNCE2001, THEN plugged in the power adapter, and after about one second pressed Enter to push the file.
I thought at first it didn't work, then suddenly the light went solid yellow, then solid green! YAY! It now works! How do I know for sure? I'm posting this message through the newly fixed WNCE2001.
Hope this helps! Cheers! 🙂
kubrick89 wrote: Hi everyone... just registered because i had same problem and want to share how i fixed it:
First this to note is that, as stated in first post, blinking power led is due to firmware corruption.
To fix it you have to follow this tutorial:
http://kb.netgear.com/app/answers/detail/a_id/18989/~/router-power-led-blinks-slowly-and-router-no-l...
Just few considerations:
-Default IP should be 192.168.1.251 (even if your unit is "bricked"). You can check it by installing any software like fing or lookatlan.
-tftp is by default disabled in windows vista/7... just google how to enable it.
-As stated in tutorial you have to wait some minutes (2 or 3) after firmware upload to let wnce2001 to write new firmware... when it's done it will auto-reboot.
Example of command using last firmware:tftp -i 192.168.1.251 PUT WNCE2001-V1.0.0.26.img
Here you can find last firmwares:
http://support.netgear.com/product/WNCE2001
Hope this may help someone
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks so much jalloma2! Was able to get mine back up and running in a "flash!" Excellent step-by-step write up as it was very easy to follow. Many kudos!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the exact problem: after a few months use, the unit (WNCE2001) suddenly starts Power LED green blinking and lost connection! Tried power up with “Reset" button hold;
"reset" button after powered up;
change to a different AC outlet;
No success!!
Any other brand of such "universal wifi adaptor" recommended?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi SV_Gary,
Can you please confirm that your WNCE2001 is running firmware 1.0.0.26 ? Also, is your modem/router updated?
Were you able to replicate the steps provided by other community members?
I look forward to hearing back from you.
NhanN
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was able to successfully flash the firmware on the WNCE2001 to 1.0.0.26 using the methods described and brought it back to a working condition. My router, a WNR2000v4, is up to date as well at version 1.0.0.60. If you would like to send out a Nighthawk X4 or X6 for feedback and firmware tests I would be more than happy to write up an honest and technically objective eval using iPhone 6 and Surface Pro 3 wireless ac network adapters.
- Mark as New
- Bookmark
- Subscribe
- Permalink
hello, I wanted to thank you for your explanation.
thanks to Italy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Fantastic!
Working again!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am a Mac user and did not see any reference to how to do the fix discussed by jalloma2. However, I was able to apply this fix from a Mac.
A couple of observations.
1. I use a MacBook air without an ethernet port. I found an older MacBook pro at work that has an ethernet port and used that machine. You can also purchase a USB to Ethernet adapter at Best Buy, the Apple Store, etc. - not expensive.
2. The link to the CNET website to download the TFTP Cient has an option to download a Mac version. You can also get the tFTP client at the Apple App Store. It works!
3. When configuring your Mac, use Network in the System Preferences ("gear wheel") app. Use the same settings for IP address, etc. specified by jalloma2. NOTE: After setting the IP address manually (and be sure to turn off WiFi on your machine), I tried to ping the WNCE2001 using the Terminal utility and I could not reach the unit; message was "timed out". IGNORE THIS.
4. In the Address field in the TFTP (Send) client, use 192.168.1.251. Press "File" and navigate to where you have downloaded the Firmware and then Start. THE WNCE2001 CAN BE FLASHED WITH THE NEW FIRMWARE EVEN IF THE PING COMMAND FAILED!!!!!
5. To test the success, with wifi still off on your computer, go to "mywifiext.net" from your browser. It will open and check that your firmware is correctly loaded an correct version (V1.0.0.26NA)
Hope that helps all you Mac users out there. Would also like to add my thanks to jalloma2 for a great post. BTW, I use this unit to connect my solar panels to my wireless network for monitoring purposes.
- « Previous
- 1
- 2
- Next »
