× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
2 Range Extenders
mleone22
2 Range Extenders
I purchased a 2nd WiFi Mesh Range Extender EX6250 because the 1st one worked so well. Very impressed. We placed one on first floor which gave us better wifi coverage upstairs too. And I purched a 2nd for the basement. But the Nighthawk App doesn't see two devices in the Network Map. Any suggestions?
Thanks
Model: EX6150v2|AC1200 WiFi Range Extender
Message 1 of 9
Guru
Re: 2 Range Extenders
Are they both connected and working?
If you log in through the browser do they both show?
Reason I ask is the app isn't always accurate
Message 2 of 9
mleone22
Login to Netgear.com? I'm looking. I don't see a link in the menu to "My Devices" etc?
Message 3 of 9
mleone22
I see it now under MyNetgear, but I only see 1 device. I have 3 green lights on my new 2nd extender. But there are 4 green lights on my 1st device. Not sure what I'm missing.
Message 4 of 9
Guru
which 3 lights are green?
I just mean log into your router through the browser. Not sure what router you have but it should have an online portal to change its settings.
Message 5 of 9
mleone22
Yes, I only see one extender in my connected devices on my router. This 2nd one doesn't seem to be connected in my router. 3 solid green lights including the Router Link LED, but the light to the right is not on.
Message 6 of 9
Guru
The light to the right of the router link led is the client link led. It won't light up until something connects to the extender.
Have you connected something to it?
Message 7 of 9
mleone22
I have no idea what that means. Can I speak to someone in customer support? Or should I simply return the device?
Message 8 of 9
Guru
You can contact customer support if you want. this is the public forum
to contact support click "mynetgear" at the top. register an account and then the device. From there you can contact support. Keep in mind that its only free for the first 90 days from purchase date (if new).
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 977 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
